Aquatica domeport
Started by Lasse ·
Aquatica domeport
  1. Is there a big difference between the Aquatica 8" and the 6" domeport. Anybody used them both? What are the pros or cons?
    Wil be using the Tokina 10-17 and Nikon 10,5
  2. I use the 6" dome all the time with the 10-17, and find the small diameter makes lighting close focus WA shots a much easier proposition.
  3. I had used both and also the 9.5" with the same lenses you have.
    The 6",as said before, is easier for CFWA and better for traveling .
    The bigger domes are sharper on the corners and better for split shots.
    Happy shooting
    JA
  4. with a fisheye lens you can probably use a 6 inch - i think an 8 inch is necessary with a wide angle rectilinear and that Aquatica's port extension recommendations are not necessarily correct.
  5. I just switched from my 14mm lens with the 8" dome to a 10-17 with the 6" dome and LOVE the new combination...have fun :angry:
    Thanks, Jean!
    It gave me at least an 1.5 lb. less weight in my Storm case as well as giving me more actual room!
