Seacam shooters- Nikon 10-24 zoom gear?
Started by brandoncole ·
  1. Any Seacam shooters know if the old zoom gear for the Nikon 12-24 f4 will fit on the new Nikon 10-24? Based on the paper specs, the max diam is the same, which I'm assuming is measured at the filter collar on the front, but not sure about the zoom ring diameter. I'm considering buying this new lens to test and compare to the 12-24, on a d300 body.
    Anyone out there try this new lens underwater yet? Regardless of which housing, I'd be interested to hear comments.
    Thanks much,
    Brandon Cole
  2. Any Seacam shooters know if the old zoom gear for the Nikon 12-24 f4 will fit on the new Nikon 10-24? Based on the paper specs, the max diam is the same, which I'm assuming is measured at the filter collar on the front, but not sure about the zoom ring diameter. I'm considering buying this new lens to test and compare to the 12-24, on a d300 body.
    Thanks much,
    Brandon Cole
    Brandon,
    Did you ever get any replys on this old post?
    Bernie Campoli
    Panama City beach,Fl
  3. Brandon,
    Bernie Campoli
    Bernie
    The same gear works on both lenses. We communicated with Brandon directly. Thanks.
  4. Bernie
    Steve,
    'Use same PVL 30-35 Port extention as Nikon 12-24?
  5. Steve,
    Bernie - As per your conversation with Liz this morning, SEACAM (Austria) calls for a PVL 40 for the 10-24 Nikkor.
  6. Bernie - As per your conversation with Liz this morning, SEACAM (Austria) calls for a PVL 40 for the 10-24 Nikkor.
    I find this link helpful in determining ports and port extension for lenses I may be personally unfamiliar:
    http://seacam.com/en/products/front-ports/port-selection
    Hit the drop down menu lower right for lens choices.
    Edited by StephenFrink
