Filters for natural light
Started by Ron Boyes ·
  1. Hi Guys,
    I have read some articles concerning using filters etc - they get way too technical for me.
    What setup do you recommend for me to try in the following application:
    Nikon D100, 12-24mm Lens Subal Housing and dome port.
    The subject will be Mantas in 7m depth - viz will be average to good (I hope)
    I have visited this site before and used twin YS 120 strobes on a F90 with some good results.
    ron
  2. Hi Ron,
    Will you be using a diopter with the lens?
    If so, that might limit your choices, as I have heard (haven't tried) that if you stack filter rings on the 12-24DX you will get vignetting.
  3. I would use the Hoya FL-D at 7m. It has the advantage of being more flexible. An FL-B filter will be too strong at that depth but still managable.
    If you use a diopter, the filter may have to go on first since the diopter will protrude from the lens ring. Mild vignetting does occur and clears up by 14mm. I suspect you could use the 77mm diopter, then a 77-82 adapter ring, and finally an 82mm filter. I don't have the parts to test that, though.
    You may be able to delete the diopter for manta rays since the subject distance won't be so close.
