Using Ikelite Dm 4200 Light Meter for flash
Started by pig in muck ·
  1. Hi
    Ive just bought an Ike U/W light meter for taking accurate exposure readings for flash photography. The (short) manual says that I need to set the camera's flash sync speed in the meter, then measure the flash, and I will get the right f-stop. It says "shutter speed cannot be changed in this mode". So am I stuck with using the flash sync speed as my shutter speed? (1/200 in this case, a Nikon D80). Can I dial in 1/125 as my flash sync speed if that's the shutter speed I want to shoot with? Or, if I stick with dialling in 1/200 as the sync speed and then get f16 as the reading, can I go to f8 at 1/125?
    It may not be much if an issue, as I'm sure I can use 1/200 but I have used 1/125 in the past and I dont want to have to open my lens up too much in case it starts to get soft.
    As ever, any advice from those more knowledgeable very very welcome.
  2. Well i emailed Ike and they got back - lovely people!
    In case you need to know / care about knowing, you can use it for any shutter speed up to your sync speed - the manual is just badly worded.
