L&M Titan D200 strobe problems
Started by twistah ·
  1. Hi!
    Just got a second hand L&M Titan D200 housing.
    The housing have two separate sync cable bulkheads.
    However, when any of my two strobes are connected to the left bulkhead connection,
    the strobe output adjustment (using the L&M Roc system) is ignored and the strobe fires
    at full power every time. Using the other (right) connection, the Roc strobe output adjustments
    work just fine.
    I have setup the Titan D200 with the correct strobe profiles on each side. Still the same problem.
    Anyone with the same experience?
    Thanks!
    /Pål O.
  2. Sounds a bit like my Nexus in that you have a Primary & Secondary bulkhead, even thou they're supposed to be the same. If using only one strobe, it must connect to the Primary bulkhead.
  3. Sounds a bit like my Nexus in that you have a Primary & Secondary bulkhead, even thou they're supposed to be the same. If using only one strobe, it must connect to the Primary bulkhead.
    Thanks for your reply.
    Just to make it clear. This problem also exists when both strobes are connected to the housing.
    The strobe that is connected to the left bulkhead, will always fire at full power.
    I even switched the two strobes to make sure that is was not a strobe problem.
  4. Thanks for your reply.
    I would suggest that you contact either Russ or Jim at Backscatter.com. Both are very knowledgeable and very helpful on the Titan D200 and the ROC system.
    Edited by foto-diver
