Dive & Camera Gear, and Film F/S
Started by Scubatooth ·
  1. Being a diver means that after a while you end up being a gear pack rat as well and its time to go through the closet and see what items that I have collected over the years that I haven't used in a while and/or my abilities have surpassed the technology and could be better used by other divers.
    The following items have been very well taken care of in all of the time I have owned them so your not getting abused gear, but items in very good to excellent condition. My photo gear is very well taken care of as my work depends on it so nothing is abused and serviced at regular intervals and kept in protective cases when not being used.
    This list is a work in progress as I find different items. Photos available on coming soon
    BCD(s) & Regs:
    Dui Delta BC (one-size fits all) $350
    -Notes: Back inflate BC, with DUI rip-cord weight pouches
    Condition: Very Good
    Dacor H.U.B. (Human Underwater Breathing system) x2 $350
    -Notes: excellent condition both have less than 50 dives on them. HUB was originally released in 2000 and is a all-in-one system that has the regulators and first stage built into the BCD through the integrated hard pack.
    Dacor Viper Regs (1st, 2nd, and octo) - yoke $175
    Light(s):
    UK Light Cannon $125
    -Notes: Black body, pistol grip handle.
    Condition: Very Good – Bulb Has less then 1 Hour of use on it
    Pelican Nemo 4 C light $20
    -New in box never used
    Misc:
    Diverite stage straps x3 $45ea
    -Notes: only one has hose clamp for alum 40 other two can be adapted for alum 40 or 80.
    Dacor 3/2 mm Shorty Wetsuit – XXL (feels like a L to XL) $20
    Black, Blue and Green – Condition Good
    Mares Avanti Quattro Fins – Blue $50
    -Brand new, never used or dove
    Poseidon Reg bag $10
    Apeks Reg Bag $10
    Camera(s) & Camera Gear:
    Olympus C5050zoom – 2 Available $225/$200
    5.1 Megapixel F1.8-2.6 35-105mm (3x Zoom)
    -Notes: One camera will come with all of the original accessories that came with the camera and the box if you would like. Memory cards 128mb x2, 1 512mb XD card, includes manuals and Olympus master software
    Condition: Shows minor useage, but no damage or dead pixels in LCD screens
    Olympus PT-015 Housing for C5050 $200
    Condition Very Good
    Includes a set of travel o-rings (so you can keep your main ones in good shape)
    Inon UWL 100 Type II Wet Lens $275
    -Notes: Item includes both lens caps
    Condition excellent – no chips or flaws
    Olympus SP350 – 2 Available $250ea
    8mp F2.8-4.9 38-114mm (3x zoom)
    -Notes: include Olympus master software (1 each camera) each camera has a 2GB memory card, also comes with a rechargeable battery packs x2 plus charger
    Condition: Very Good / Excellent
    Olympus PT-030 housing for SP-350 $575
    -Notes: This housing is modified with a Heinrich Weinkamp TTL adaptor so that with a sync cord you can have a hardwired TTL to a strobe. Additionally there is the Inon AD mount adaptor for the AD series of Lense. This housing, adaptor, and lens mount originally cost of $750 to have set up.
    Condition: Excellent – Includes extra orings as well
    Inon UWL105AD Wide Angle lens $225
    Inon UCL 165AD Macro Lens $125
    Inon dual lens caddy for AD mount $55
    Nikonos V w/ 35mm Lens $200
    -Notes: was serviced after last use in 08. Also comes with UW photo tech body cover
    Nikonos 20mm w/ Viewfinder $175
    -Notes: in very good condition(no mold) and includes UW photo tech lens cap
    Sekonic Underwater Light meter $100
    -Notes: Includes leather case, instructions and security cord. Battery replaced in 2006 and still in very good condition
    Canon Elan 7e with Hand grip & strap $125
    -Notes: This is a film camera and has about 250 rolls through it. Shutter and body where checked out in fall 07 by canon professional service, and checked out fine
    Condition: Good – shows a fair amount of use In dusty environments but nothing that effects function.
    Canon 1V-HS 35mm Body $1200
    Mamiya 645e Medium Format Manuel Focus Camera $400
    Notes: Comes with 2 lenses 80mm & 150 mm, x inserts x-120, x-220. Camera is Manuel focus and manuel shutter speed set via a dial on the top of the body. The prism does have a meter in it, its is a center-weighted (IE takes readings off the middle of the bulls eye in the prism)
    Mamiya 645AFD Medium Format AF Camera $2200
    -includes 80mm lens, 150mm lens, Polaroid Back, 3 120/220 Film backs
    notes: body is compatible with the latest digital back including Leaf 6,7,8, & 9
    Custom Camera Tray with carry handle $250
    -Notes: This tray was custom bent and machined to my specs, and hard anodized. Tray design is multi-functional and can be set up from single handle and strobe all the way to full tray with carry handle capable of supporting dual strobes, and additional accessory lenses. Also includes a secondary camera mount plate so you can have two rigs on one tray. Second plate is machined so that it can be mounted on a tripod for long exposures.
    Condition: Very Good – does show scratches in anodizing, but doesn't affect function. Ball mounts not includeds
    ULCS TR-D Camera tray with padded handle and ball mount $60
    -Notes: gray handle
    Condition: Excellent – used for one trip
    Film:
    The following films have been stored in a lead lined deep freezer (0 to -20 deg F) since they were purchased. The boxes may not be in the best shape but the films are still good.
    35mm Color:
    NPS 160 135-36 x38 rolls exp 2/2007 $2 ea $65 for all
    NPH 400 135-36 x 2 rolls exp 12/2007 $5 for both
    NPZ 800 135-36 x14 rolls exp 6/2007 $2ea $25 for all
    Velvia 50 135-36 x25 rolls Original Velvia 50 exp 7/2006 – 1 Sealed Box + 3 loose rolls $5 ea $100 for all
    -I just shot rolls of from the same batch that are in the freezer and there is no color shifts when shot at ISO 40 processed normally.
    Velvia 100 (Not F) 135-36 x5 rolls exp 12/2006 $5 ea $20for all
    Provia 100F 135-36 x3 rolls exp 12/2008 $5 ea $10 for all
    120 Color:
    Provia 100F 120 x 3 rolls exp 12/2004 $3 ea
    Velvia 50 120 x25 rolls exp 6/2006 $8 ea $150 for all
    -Original Velvia 50 no color shifts noted on other rolls shot from this batch
    Veliva 50 220 x 10 rolls exp 8/2006 $10ea $80 for all
    Kodak Ultra Color 100 UC 120 x 12 rolls exp 2/2006 $2 ea $20 for all
    NPS 160 120 x19 rolls exp 4/2006 $1 ea $35 for all
    NPH 400 120 x 94 rolls exp 6/2006 $2 ea $150 for all
    -75 rolls in 5 roll propacks 19 rolls loose – film was recently tested in studio and outdoor conditions and no loss of speed or image quality problems noted on 8000 dpi Tango Heidelberg scans
    35mm B&W:
    Kodak TMAX 100 135-36 x13 rolls exp 1/2006 $2.50 ea $25 for all
    -2 rolls in box, rest loose in canisters
    Ilford Delta 100 135-36 x 14 rolls exp 5/2007 $2.50 ea $25 for all
    -5 rolls in box, rest loose in cannisters
    Ilford FP4 Plus 125 135-36 x 7 rolls exp 8/2008 $2.50 ea $13 for all
    Ilford HP5 Plus 400 135-36 x2 rolls exp 9/2008 $2.50 ea
    Kodak BW400CN 135-36 x8 rolls exp 11/2007 $2.50 ea
    Kodak 400TX 136-36 x 10 rolls exp 12/2006 $2.50 ea $20 for all
    -50th anniversary packaging
    Kodak 400TX 135-36 x 5 rolls exp 5/2006 $2.50 ea $10 for all
    - 3 rolls in Box, 2 rolls no box just cannister
    Kodak P3200 TMAX 135-36 x 5rolls Unk Exp date $2.50 ea $10 for all
    Ilford Delta 100 135 100 Ft roll exp 10/2007 unopened $25
    Illford Delta 400 135 100ft exp 12/2007 $40
    -also includes 8 hand rolled 36 exp rolls, film winder, 12 iso 400 DX cartridges, 1 roll of splicing tape
    120 B&W:
    Ilford Delta 100 120 x 4 rolls exp 7/2006 $2.50 ea
    Kodak TMAX 100 120 x11 rolls exp 4/2006 $2.50 ea $20 for all
    Ilford FP4 Plus 125 x 10 rolls 2/2007 $2.50 ea
    Ilford Delta 400 120 x 3 rolls exp 10/2006 $2.50 ea
    Kodak 400TX 120 x10 rolls exp 3/2008 $2.50 ea $20 for all
    -50th Anniversary packaging
    Ilford XP2 super 120 x 3 rolls exp 4/2006 $2.50 ea
    Kodak BW400CN 120 x28 rolls exp 3/2006 $2.50 ea $60 for all
    -Process C-41
    Kodachrome
    Kodachrome 25 KM 136-36P x4 rolls exp 6/1984 $10ea
    Kodachrome 25 KM 135-20P x 6 rolls exp 4/1984 $10ea
    Kodachrome 64 KR 135-20P x6rolls exp 8/1984 $5ea
    Kodachrome 200 PKL 135-36 x 8 rolls exp 5/2004 $5ea
  2. PM Sent
  3. To those that sent me PMs about items. Im currently at work(on a short break before our next transport leg) and wont be off till tuesday morning; I will answer questions then.
    Thanks for your understanding
