Aquatica Wave Housing for Canon HFS10 / 100
Started by pmooney ·
    Edited by pmooney
  2. Nice!
    Anyone done a test drive?
  3. Here are some of the specs and features (which will include a lens shade for the LCD monitor) :
    Included Standard Features:
    • Marine grade solid aluminum construction
    • 30˚ angled large 2.7" LCD viewfinder for easy viewing
    * NEW HYBRID design, mechanical controls combined with electronics
    will allow access to almost ALL camcorder functions, including the crucial
    manual white balance. (BOTH MECHANICAL AND ELECTRONIC CONTROLLED)
    * Wide angle port with macro adapter, a multi-purpose performance
    lens giving 65˚FOV with full zoom through & 85˚FOV with partial zooming.
    (SAME LENS FOR WIDE AND MACRO)
    • Internal flip filter arm with UR Pro blue water color correction filter
    • Sensitive hydrophone to capture clear underwater sound
    • Water sensor alarm with blinking LED
    • Bayonet mounted lens system with lock
    • Auxiliary port to connect external accessories
    • dual grip system including light mounting points for TLC arms
    • 2 large secure lockable stainless steel latches
    • 300 feet/ 90 meter operating depth
    • Compact & light weight for easy travelling, only 8 lbs dry weight
    SPECIFICATIONS:
    Construction:
    - Marine grade solid aluminum
    - Fully anodized with a hard coat of polyurethane paint
    - All hardware is marine grade aluminum & stainless steel
    Controls:
    - On/Off
    - Mode Dial
    - Record/ Standby
    - Photo
    - Zoom Telephoto / Zoom Wide
    - Full Menu access
    - Full Function access
    - Manual Control Knob to access Custom command, (Exposure, focus, assist functions, AGC limit)
    - Display button
    Features:
    - Flip filter Arm with UR Pro blue water color correction filter
    - Sensitive Hydrophone to capture clear underwater sound
    - Water sensor alarm with blinking LED
    - Bayonet Mounted Lens System
    - Auxiliary port
    Ports:
    - Wide angle port: (INCLUDED AS STANDARD with housing) A good all around performance lens giving 65°FOV with full zoom through, & 85° FOV with macro adapter off the port, giving partial zooming. Same lens for wide and macro.
    - Standard dome port: Optically corrected to give 1:1 angle of view underwater, (makes a good back-up lens)
    - Flat port: Best choice for macro work, allows full zoom through with diopters.
    Dimensions:
    - 7” D x 4.8” H x 9.5” W (14.5”with handles)
    - 17.7cm D x 12.2cm H x 24cm W (37cm with handles)
    Weight:
    - On land 7.5lbs (Kg) fully loaded w/camera battery and lens.
    - In seawater slightly negative buoyancy
    Operating Depth:
    - 300 feet / 90 meters
    RETAIL PRICE / RELEASE DATE "TBA"
    Edited by Drew
