FS: Gates Xh A1, Green Force 250 and other accesories
Started by geoffreyweglarz ·
  • 12Posts
  • 12Replies
  1. Paid 18 asking
    months ago
    Gates XHA1 Housing $5745 $4000
    Gates Moisture Alarm $167 $115
    Gates Microphone $210 $165
    Gates EM43 HD Monitor $2325 $1900
    Gates SWP44 Super Wide $4482 $3200
    Greenfoce 2 Gates Green Force
    HID 250 Video Light Pak
    with 2 FII Batteries $3825 $2700
    Gates Extended Balance Arms $330 $200
    Gates Tripod $570 $400
    Pelican 2 Pelican cases for
    transport NC NC
    Sub-total $17654 $12680
    XH-A1 can be included in the '
    full pakage for $3500 $2500
    Total $21154 $15180
    http://www.gateshousings.com/XH.html
    http://www.gateshousings.com/accessories.html#alarms
    http://www.gateshousings.com/EM43Monitor.html
    http://www.gateshousings.com/hiperport.html
    http://www.bhphotovideo.com/c/product/4861...0.html#includes
    Unit just factory serviced by Gates last month.
    Will consider selling pieces, but not camera alone.
    All prices listed OBO
    I am downsizing and am looking for a smaller unit.
    Edited by Drew
  2. Hi Geoffrey, great meeting you last night!!! Send me all the info, and if you have the pics, please resend those as well. Thank you!
  3. Hi Geoffrey, great meeting you last night!!! Send me all the info, and if you have the pics, please resend those as well. Thank you!
    Hey Mike. Great to finally meet you. I am taking photos today and will e-mail them to you when I'm done.
    Thanks.
  4. Gates XHA1 Housing
    Gates Microphone
    Greenforce 2 Gates Green Force, HID 250 Video Light Pak, with 2 FII Batteries, Gates Extended Balance Arms
    Gates Tripod
    Pelican 2 Pelican cases for transport
    This unit also fits the Canion XL H1 and can be upgraded for the new Canon XH A1s from Gates for $950!
    http://www.weglarz.com/pictures/gates/
    http://www.gateshousings.com/accessories.html#hardware3
    0ne more year warrenty remaining.
    Asking $10,000 OBO.
    Edited by geoffreyweglarz
  5. Gate XH A1, XH A1s, XH G1, XH G1s housing. http://www.gateshousings.com/XH.html. Includes Handles, Gates Moisture Alarm and microphone
    Controls (All Mechanical)
    ● Power (Auto/Tv/Av/M) ● Record/Standby
    ● Zoom ● Manual Focus
    ● Internal ‘Flip’ Color Filter ● Iris
    ● Auto / Manual Focus ● Exp Lock
    ● Custom Key 2 / WB Set ● Magnify / Peaking
    ● Neutral Density Filter ● Gain / WB Presets
    ● Shutter ● Custom Presets
    ● Internal ‘Flip’ Macro (optional)
    ● Dimensions (approximate)
    ● 16.3" L x 9.1" H x 6.8" W ” (12” w/handles)
    ● 41 cm L x 23 cm H x 18 cm W (31 cm w/handles)
    ● Construction
    ● Machined Aluminum, Type III ‘Hard’ Anodize
    finish. Stainless steel hardware.
    ● Weight
    ● 24 lbs / 10.8 kg
    ● 19.5 lbs / 8.8 kg w/o travel weight
    ● Weight in Water
    ● Slightly negative
    ● Depth Rating
    ● 450 feet / 137 meters
    ● Batteries
    ● Accepts all Canon batteries
    ● Warranty
    ● 2 Years Renewable
    Asking $4000 OBO
  6. Gates EM43 HD Monitor
    by Geoffrey Weglarz on Jul 17, 2009 at 10:45:26 am
    Gates SD/HD EM43 Monitor
    Specifications
    * Display
    * Widescreen 4.3 in / 110mm active matrix color LCD
    * Total Dot Count: 392K (1440 x 272 R+B+G)
    * Controls --None
    * All functions auto-sensing.
    * Dimensions
    * 6.0" W x 4.5" D x 3.9" H
    * 152mm W x 114mm D x 99mm H
    * Formats
    * SD version: NTSC and PAL (auto sensing)
    * HD version: 1080i/60 • 1080i/50 • 720p/60 •
    720//50 (auto sensing)
    * Power
    * 8 AA Cells. Alkaline, NiCad, NiMH or Lithium
    * Material
    * Machined aluminum, type III ‘hard’ anodize
    with nickel acetate seal.
    * Weight (w/lithium batteries)
    * Dry: 3.1 lbs / 1.4 kg
    * In Water: Neutral
    * Depth Rating
    *450 feet / 137 meters
    * Warranty
    * 2 Years Renewable
    * Connections
    * Industrial-grade 2-Pin E.O. type (SD)
    * Industrial-grade 6 Pin (HD)
    Asking $1650 OBO
  7. http://www.gateshousings.com/hiperport.html
    • Performance – 120° wide FOV with full zoom through capability for macro subjects.
    • HD tested and qualified – for the finest HD images possible.
    • Distortion-free – for clear, sharp images from corner to corner.
    • Reflection-free – no image-destroying flare or reflections.
    • Vignette-free – means no cutoff dark corners to ruin an image.
    • Use in Air and Water – and for air/water split shots (when compatible).
    • High grade optical glass elements – for sharp, crystal clear high resolution images.
    • SiO2 AR Coating– is durable and efficient for max light transmission.
    • Nitrogen purged/vacuum sealed optics – means no dust or condensation inside.
    • 2-year warranty – consistent with all Gates products.
    The SWP44 is compatible with the following Gates housings:
    • FX1 / Z1 • XL H1 • XH A1s• HVX200
    Asking $3200 OBO
  8. http://www.bhphotovideo.com/c/product/4861...A_Green_Force...
    The Gates Green Force HID 250 video light system with two 50W HID light heads and articulating arms is designed for the professional or recreational camcorder operator. The light heads are constructed of aluminum with glass diffusers. The lights will operate to a depth of 500'.
    Features include a 55 minute burn time and the 50W HID lamp that is 2 to 3 times brighter then a halogen bulb. Each light has a 3800° kelvin color temperature. This is warmer then most HID Lamps and will help bring back the reds and yellows into the scene.
    The glass diffusers are very efficient and produce an even light with no hot spots. The lights will cover a 110° area. A bracket to attach the batteries to a Gates housing is included.
    • Rugged Construction
    Aluminum with glass diffusers
    Acetyl battery casing.
    • 50W HID lamp is 2 to 3 times brighter than a halogen bulb.
    • Wide 110° beam angle.
    • Warm 3800°K color for more reds and yellows.
    • Heads with glass diffusers are very efficient and produce even light with no hot spots.
    • The FII battery packs with fast 3.5 hour international smart charger.
    • Articulating arms are included.
    • Includes bracket to attach battery to Gates housing.
    Asking $3200 OBO.
  9. Gates Tripod
    * Dimensions
    * 8in W x 12in L x 2” H (collapsed)
    * 20cm W x 31cm L x 5cm H
    * Legs
    * Fully articulating.
    * Extensible 7 to 18in (18 to 46cm)
    * Warranty
    * 2 Years.
    * Construction
    * 100% Aluminum w/type III ‘hard’ anodize & Nickel Acetate Seal. Stainless steel hardware.
    * Weight
    * Dry: 2.8 lbs / 1.3 kg.
    * Wet: -2.3 lbs / 1.0 kg.
    * Compatibility
    * All Gates housings
    Asking $350 OBO
  10. Hi Geoffrey
    How old is this monitor? Does it still have full warranty?
    Thanks for the info, cheers Doug
    Specifications
    * Display
    * Controls --None
    * Dimensions
    * Formats
    * Power
    * Material
    * Machined aluminum, type III 'hard' anodize
    * In Water: Neutral
    * Depth Rating
    * Warranty
    * 2 Years Renewable
    * Connections
    Asking $1650 OBO
  11. Doug,
    Ill help Geoffrey out here as we are trying to help him sell it. The monitor is a year old. Its in excellent shape. Still a year of warranty left on it. It was just recently serviced by the factory as well. If you have any other questions, do not hesitate to send me or Geoffrey a message.
    Edited by Drew — Removing ebay link
  12. Please update the original thread only and do not start new topics for each item you listed in your original thread. This helps people using search engines. If you need to update prices etc, just add a reply to the thread. We do not allow double posting of items for sales. Thank you for your cooperation.
    Edited by Drew
