D80 housing & lens
Started by cboggs ·
D80 housing & lens
  1. Hi gang,
    anyone using a Nikon D80 and housing????
    any advice on buying a housing for this camera?, .. I'd like to find something used but good like
    an Aquaitica with a dome for over/unders.
    What's the current good lens for the over/under shots?
    I used to use a Sigma 14mm on my F4 housing, .. but haven't shot in a few years.
    Curtis
  2. you may have a look at the Wetpixel classifieds for an Aquatica D80 housing, there should be a few in there. You could also start a "want to buy" used D80 thread in there.
    For over/under shots with the D80 as a crop sensor camera, you will need either the Nikon 10.5 fisheye or the Tokina 10-17 fisheye zoom. Your other option would be a wide lens like the 10-22 for no fisheye effect.
    Best
    Mike
  3. I use Sea&Sea Dx-D80 with NX Fisheye Dome Port. Come in all black to match my other black equipments :)
    Sea&sea discontinued the production of the housing so you need to check the availability from the shop. For a good Over/Under shot you probably want as wide angle lense as you can afford. Have a look at Nikon 10.5mm as sugeested above. It's my favourite lense. It's a very sharp lense and give a very vivid colour result comparing to another lense when shooting at the same condition.
  4. thanks for the replys, ..
    issue with the 10.5 is it's a fisheye, ..
    my old set up ( haven't shot in 5 years ) was the old Sigma 14mm on a film camera in an Aquatica housing, ..
    and I LOVED the over / unders with no distortion of the fish eye.
    Look in the "swimming" section of my web site for examples. http://www.cboggs.com
    Does this mean to really do what I'm after I need to go to a full frame camera???? and if so, what lens then???
    I'm going to be shooting people in the over / unders, .. fairly close to full frame and don't want distorted people with
    big heads and tiny feet etc, .
    Is there a lens combo to do that with the D80???????
    Curtis
    Edited by cboggs
  5. the Sigma 10-22 is a wide lens that is not fisheye. That would be your best option i would say
  6. the Sigma 10-22 is a wide lens that is not fisheye. That would be your best option i would say
    Thanks Mike, . how is the Sigma on sharpness?, ..
    curtis
