Ike Ds-125 with 160??
Started by kornse ·
  1. At the moment i only have 1 strobe, the DS-125.
    Is there any problems with buying a 160 and using the two together?
    Mads
  2. Shouldn't be. As near as I can see the 160 is just an 'upgraded' 125, so they should accept the 'same' setting on the TTL circuitry. The only thing I can see about it in Ike's FAQ (and this is just general advice for mismatched strobes - nothing showed up regarding the 160/125 combination that I could see specifically) is the recommendation to use the 'weaker' of mismatched strobes as the secondary (red band on the dual sync cord).
    Edited by rtrski
  3. Thanks Rtrski. I´ll keep that in mind.
    Damnit now i have to find a way to get the money for a new strobe!! :)
    Mads
  4. i use that setup, DS160 on the left, DS125 on the right:)
  5. i use that setup, DS160 on the left, DS125 on the right:)
    Me too with the red band on the right, DS125. Just did 4 days of diving at La Rascasse at Manado in July and had no problem with the DS125/DS160 setup, shot fisheye with Tokina 10-17mm, and macro with AFS60 and AFS105 on the same setup.
