Sharpening with Photoshop
Started by Osprey ·
  • 11Posts
  • 11Replies
  1. I use CS3 ...
    Following the advice read I always apply some sharpening to my pictures after I have finished any other processing. Just using 'sharpen' filter I have been told is not teh best way.
    The technique I have been following is:
    Duplicate Layer
    Select new layer - set blend mode to Hard Light
    Run High Pass Filter and adjust until color just appears and edges define (which always seem to be around a value of 4.5 to 5.5)
    Then set blend mode to Overlay
    On the Ron Bigelow pages on blend mode if I read it right seems to be saying:
    Duplicate layer
    Select new layer - set blend mode to Overlay
    Run high pass filter
    Which is the optimum way of doing things for best results ?
    Edited by Osprey
  2. There really is no 'best' way to sharpen. Essentially every book or article you read has a different take. One thing almost all agree on is that the degree of sharpening will depend on whether you are sharpening for screen or print, and the planned size of the print. So you have to sharpen differently each time depending on output.
    I would say that for most purposes at least for computer display purposes, the Smart Sharpen filter in Photoshop is excellent, as of course it was clearly developed for the purpose. I'm not saying there is anything wrong with your approach, but I'm guessing from your post that the approach you use you gleaned from an article you read and that you are not familiar with all the different ways to sharpen. I think that unless there is a special reason to use your approach, it is more complex, with more steps than you need. Sharpening on a new layer is a good idea. Some people recommend using a Luminosity layer....but then I digress, there are so many ways and options. I'd say start simple with Smart Sharpen and add other approaches as you learn more or your needs change.
  3. I would say that for most purposes at least for computer display purposes, the Smart Sharpen filter in Photoshop is excellent, as of course it was clearly developed for the purpose. I'm not saying there is anything wrong with your approach, but I'm guessing from your post that the approach you use you gleaned from an article you read and that you are not familiar with all the different ways to sharpen.
    I had just been reading articles here and other sites ... and picked up the 'instructions' there.
    Mu use is to create images for sharing - to be watched on a PC screen or TV via a DVD player.
    I have no experience of Smart Sharpen ... can you give any tips as to how to use it ?
  4. As I said, I'm not being critical, just think that especially starting out, keep it simple and then change if you find something better.
    Basic starting steps for Smart Sharpen:
    Filter > Sharpen > Smart Sharpen
    Click Advanced button
    Start with settings of 200 and .8 with Remove Lens Blur and More Accurate checked.
    Adjust with Preview button checked to taste.
    Sharpening is basically increasing contrast at the edges to enhance the impression of sharpness, and taking it as far as you can without making it look unnatural or create artifacts.
    Give it a try, you may prefer the way you do it, and you will probably try other ways as you read more, as I said there really are many ways to do it, just don't make it more complicated than you need for your purposes.
  5. I also sharpen using the high pass method...the 2nd one listed in your first post, with one step added. The overlay can be set for 0-100% transparency with a slider in the layer window. This allows you to select the level of sharpening you desire. With the slider, you can control the level of sharpening and select between 0-100%. I find 70% is usually as far as I want to go without creating something that looks over done.
    Hmmm...I think I'm now going to check out Jeff's method as well since I've never done the advanced tab. Just using the smart sharpen without advanced sometimes overbaked things :?)
  6. Hey Ospray,
    If you shoot in RAW try using the sharpen options in the ACR (Adobe Camera Raw) interface, the little twin triangle icon in the menu bank just below the histogram.
    Once opened you'll see four sliders - Amount, Radius, Detail & Masking.
    Increase the image size to 100% before applying any adjustments.
    Ammount adjusts the edge definition
    Radius adjusts the size of the edge
    Detail controls the level of sharpening applied to fine details like textures
    Masking helps to restrict the sharpening to the main details
    Here's a really neat feature, by holding down the Alt key whilst moving the slider you get an overlay mask and can see exactly where the sharpening is being applied. You can set the ammount as you want and know what's beeing sharpened
    When you've done all the sharpening you can apply some noise reduction (if needed) all in the same dialogue box.
    Those Guys at Adobe are the "Mut's Nut's"
    Hope this is of help
    Nige Wade
  7. Hey Ospray,
    Nige Wade
    No previous camera had RAW output, current camera does not.
  8. I use the highpass method
    Cntrl J (duplicate layer)
    Overlay
    Highpass - 3 (or just a percipitble difference)
    then click the layer on or off to see the difference and adjust the opacity slider accordingly
    Cal
