First rolls....
Started by riodda ·
First rolls....
  1. I did in my last dives hte first rolls of film with the V.
    I was about 18m at elba island, i was using an 800 an a 400 film and i have to say that most of the pictures looks underexpposed about 1/3 stop more or less...i should warry about the meter or it's just me ???
  2. I would always bracket exposures with the Nik V. at least 2 or 3 fstops per subject. You can also trick the meter by adjusting your ISO on the camera to purposely overexpose by not setting it on the correct ISO but rather slightly less than your real ISO
  3. have to say that most of the pictures looks underexpposed about 1/3 stop more or less...i should warry about the meter or it's just me ???
    In the past, a lot of underwater photographers used to use the Sekonic Marine Meter II when using the Nikonos V. Even though the Nik V has a meter, some photographers prefered to use an external meter. I wouldn't rush out and buy one, but if you're going to stay with the Nik V for a while and you're not happy with the exposures you're getting, it's something to think about.
    See the following link:
    And, as Mike says, get in the habit of bracketing your exposures. Shooting film doesn't give you the opportunity to get instant feedback in the form of a histogram, so bracketing is definitely a way to cover yourself and make sure you get the shot.
    Ellen
  4. I feel like I just stumbled out of the WABAC machine. Help me Mr. Peabody! :)
  5. I did the third roll, but the idea of bracket with the iso it's good, i'll do it for sure.
    Do i need to do it even with the use of flash ?
