D700/D3x and corner sharpness
Started by sharky1961 ·
  1. Hi,
    I am thinking of moving to FX but what is holding me back is the problems with the corner sharpness. I don't want to invest money in a new camera and housing and come back with less IQ pictures regarding wide angle. Wich of you is really satisfied with your corner sharpness when using wide angle lenses ( not Fisheye lenses)???
    Alex have you figured out what dome-extensionring gives you the best corner sharpness???
    Rob
  2. I am happy with the corner sharpness with the 17-35mm and 28-70mm, which are the two wide angles I use routinely with my D700. I use a dioptre on each with my Subal.
    Others are happy to not use a dioptre and get sharp corners.
    So I think in general most people are happy with the corners as long as you find a good port set up and compose images with a little care.
