Light and Motion Titan D100
Started by jnich ·
  1. have a Light and Motion Titan D100 underwater Housing with a D100 body for sale;
    Flat Port accommodates 60mm
    Extension ring 2 854-0135-A accommodates 105MM
    Various unused O-rings, 2 unused complete O-ring kits w/batteries
    Overhaul performed 8/23/07 with 200 ft pressure test – has not been wet since. Bulkheads cleaned & checked. Electronics tested. Spent $225 for this – receipt included.
    Manuals included
    Unused 825-0540-A 105MM focus gear
    Unused 825-0538-A 105mm A/M gear
    2 used wetmate housing to strobe cords
    $1,000 with D100 Camera Body – no lens
    http://uwimaging.com/downloads/titan/Titan_D100manual.pdf
    Edited by jnich
  2. Thanks :) - Found one :)
    Edited by tirsales
  3. Do you still happen to have this housing for the Nikon D100 available? Can you send me some actual pictures of it? Would you be willing to split the D100 body up from the housing? You can send them to seanparrish@cableone.net
    Thanks for your time and consideration,
    Sean
