cs4 question
Started by vazuw ·
cs4 question
  1. I got cs4. When I try to open a raw file from cs4 bridge, it opens it in cs3 as the default. How do I change the default so when I open a raw file in cs4 bridge, it opens the file in cs4 developer? Thanks gurus
  2. delete cs3
  3. I got cs4. When I try to open a raw file from cs4 bridge, it opens it in cs3 as the default. How do I change the default so when I open a raw file in cs4 bridge, it opens the file in cs4 developer? Thanks gurus
    I don't have CS4, but you might try this:
    Open CS4 Bridge, and then open its 'Preferences' window from the drop-down list under, "Bridge CS4."
    In the left hand pane, select, "File Type Associations."
    In the right hand pane, find your camera's RAW file type (look for Nikon Electronic Format (.NEF) for nikon user, Canon Camera Raw (.crw, .cr2) for Canon user, etc.)
    If you click on the application listed to the far right, you should be able to Browse to CS4 as the default app for that file type.
    This should allow you to keep both versions if you want to. I hope this helps
    Randall
