Canon G9 control dial workaround?
Started by nputtick ·
  1. Hi
    using a G9 in the Canon DC-21 U/W housing there is no way provided to rotate the rear control wheel. As a result certain controls cannot be used, except by pre-setting.
    the two that really bother me are:
    1. f-stop setting in Av mode
    2. +/- exposure compensation
    Does anyone know if there is a button-press workaround for these?
    I know I can set C1, C2 (for example to use a predetermined f5.6 and f8 in Av mode) but this is pretty restrictive giving just two choices.
    Nigel
    Edited by nputtick
  2. Not true ...
    Press and hold the * button on the upper left and then 'spin' by using 'left' and 'right' on the d-pad.
  3. Thanks Jeremy - indeed that is what I've just found on Scubaboard - here;
    http://www.scubaboard.com/forums/canon-cor...tml#post4667214
    However it's not the * button - the top left one is marked S (and can also be used on its own for a custom action)
    This is really useful info and I hope of value to anyone having the same issue with the G9 or G10 (and possibly G11?)
    It doesnt' seem to be in the manual for the G9 or the WP-DC21 - it should be!
    Needless to say I'm really glad to have found this after weeks of searching and just about to go to the Red Sea... ;)
    Nigel
    Edited by nputtick
