Disable strobe in menu EOS 5D mkII ?
Started by olawelin ·
  1. Hello, i have just installed a internal Heinrich Weikamp TTL converter in my Aquatica housing for the EOS 5D mkII with 2 Sea & Sea YS-110 and it works fine but there is one problem:
    I want to disable the strobes to use the cameras exposure metering without strobes but as long as the TTL converter is connected the camera thinks there is a strobe (even when i turn of the strobes or put the TTL converter in manual mode) and the exposure metering don´t work correctly.
    Anyone know if there is a way to disable the strobes in the menu of the 5D or anything else to do?
    Ola
  2. Hello, i have just installed a internal Heinrich Weikamp TTL converter in my Aquatica housing for the EOS 5D mkII with 2 Sea & Sea YS-110 and it works fine but there is one problem:
    Ola
    Ola, in what way do you feel that the exposure is different with and without the flash? That can only be in the P mode (or green mode) right? In Av, Tv and M the exposure is done as when you don't have a flash attached. Or do you have different experience?
    /Björn
  3. Ola, in what way do you feel that the exposure is different with and without the flash? That can only be in the P mode (or green mode) right? In Av, Tv and M the exposure is done as when you don't have a flash attached. Or do you have different experience?
    /Björn
    Tried the AV and TV modes yesterday and they work as you describe so that is what i was looking for, strange is that i tried them earlier and they didn´t work but maybe the cables were wrong.
    P mode doesn´t work but thats no problem, thanks
    //Ola
  4. Sounds like you got it sorted Ola. You'll also find in the menu an option to let the shutterspeed vary when you have a speedlite attached, or lock it at 1/200th. Obviously you don't want to lock it at 1/200th :-)
