Sigma 150 Macro In Subal
Started by gregarius ·
  1. I have a Sigma 150 Macro that I'd like to use in a Subal 5D. I have the FP-90/3 port but am not sure about which extension to use. I've asked Backscatter and a couple other places and they don't know.
    Anyone using this setup or something similar?
    Can I just measure the difference between the 100 macro and the 150 and use something close, something that doesn't see the outer area of the port?
    Help appreciated.
  2. I have a Sigma 150 Macro that I'd like to use in a Subal 5D. I have the FP-90/3 port but am not sure about which extension to use. I've asked Backscatter and a couple other places and they don't know.
    Help appreciated.
    If you believe the sizes quoted by the manufacturer, the sigma 150 is 17 mm longer than the canon. There are both 18 and 20 mm extension rings for subal
    Bill
  3. If you are going to house the Sigma 150mm do make sure that you leave room in the port for a Canon 500D dioptre. I would say I fit the Canon 500D to the Sigma 150mm in 9 dives out of 10. The dioptre is surprisingly thick - about 15mm.
    I use a standard Subal 100/105mm port with small extension ring (guessing 18mm).
  4. If you are going to house the Sigma 150mm do make sure that you leave room in the port for a Canon 500D dioptre. I would say I fit the Canon 500D to the Sigma 150mm in 9 dives out of 10. The dioptre is surprisingly thick - about 15mm.
    Thanks guys.
    Alex, do you know what the minimum focus distance is with the 150, using the 500D?
  5. Alex, do you know what the minimum focus distance is with the 150, using the 500D?
    No, sorry. But this was shot with it. This is the full frame, uncropped - Sigma 150mm and 500D:
  6. No, sorry. But this was shot with it. This is the full frame, uncropped - Sigma 150mm and 500D:
    Thanks for posting, Alex.
    I have a Macromate. How would using the Macromate with the 150 macro differ from using the 500D on the 150 macro?
