Coolpix 5000 speedlight compensation
Started by ReelBruin ·
  1. Hi-
    Another question - I read that it's recommended to set the speedlight output compensation to -2 on a Coolpix 5000 because of the location (physical) of the TTL sensor on the camera when doing Macro.
    Does this hold for wide-angle or standard shooting?
    Thanks!
  2. Set it max compensation and your synch speed to about 1/500th. But do yourself a favor and get the manual strobe controller so you don't have to waste your time.
  3. Where/how do you set the synch speed? Do you mean shutter speed? And by max compensation, I assume you mean max negative compensation...
    Thanks a bunch. I'm a long time Nikonos shooter, new digital shooter.
  4. In the menu there is a setting for speedlite compensation. Set it to - compensation. Yes I ment shutter speed.
  5. Thanks.
