Alternative current or compact fluorescent underwater?
Started by softnuance ·
  1. I am trying to build a continuous underwater lamp that will do video and still… no more strobes.
    I would like to try 2 conventional 40W Compact fluorescent lamp that do 2200 lumens each.
    Pros: affordable, easy to replace, no heat management
    Cons: big, heavy
    Problem: It implicates alternative current underwater, and no one uses AC underwater: pool, boats, diving, etc.
    Is there a reason why I should not use an AC or compact fluorescent underwater?
  2. I just found possible answers: 40 000 Hz with salt water might be a problem. The emitted radiation could be a problem for fragile corals. LEDs produce more Lm/w... it means a smaller battery, less weight.
    Edited by softnuance
  3. Power compact lighting is commonly used on aquariums and corals like it just fine. AC current however is not :-)
