S&S 110a
Started by ckchong ·
S&S 110a
  1. hi....need some info.. S&S 110a can do S-TTL using Optically fired like Inon Strobe (S-TTL)????
  2. hi....need some info.. S&S 110a can do S-TTL using Optically fired like Inon Strobe (S-TTL)????
    Hi Chong,
    strange to have to communicate to you here...
    The YS-110 Alpha has DS-TTL ( Digital Slave Through The Lens) , you can verify it at Sea&Sea webpage.
    Ultimate creative effects with subtle light balance
    The YS-110α introduces numerous new exciting functions, opening a whole new digital generation. For example, by connecting it to digital cameras with pre-flash function using a fiber-optic cable, the YS-110α can be used in the fully automatic DS-TTL adjustment mode (Digital Slave TTL). Enjoy complete creative control – when you want absolute control over fine light adjustments, you can use a main strobe in DS-TTL mode and a secondary strobe in manual mode or you can set up an advanced lighting system using two strobes in DS-TTL mode. The DS-TTL adjustment function is also available using the light level control dial for fine control of the light amount when taking pictures in DS-TTL mode. You can also choose from 13 levels of manual controls when you do not want to leave the light adjustment up to the camera. The flat, round, 105° beam angle (with diffuser), achieved by the balanced positioning of the 3 flash tubes, and the power of a Guide Number 22 are examples of the excellent performance of the strobe that is sure to satisfy even the most demanding professionals.
    Hope this helps....
  3. hi....need some info.. S&S 110a can do S-TTL using Optically fired like Inon Strobe (S-TTL)????
    I have a S&S 110a and have finally made it work with my Olympus SP550UZ compact digital camera
    with an optical cable from the camera to the strobe.
    You need to have the camera set with pre-flash mode on
    The strobe needs to be set in TTL with the slave on and the meter set to full....
    Works like a charm (at least out of the water - I'm going to take it diving soon)
    I just purchased a second 110a to eliminate some of the shadowing I've been getting in manual mode
    Wrote to S&S and they confrmed that the second strobe will also work in TTL...
    cable can be connected either to the camera or to the 1st strobe.....
