What port extension do I need for the Subal DP-SUP 10"?
Started by Sebastian ·
  1. Hi,
    what port extension do I need for the Subal DP-SUP 10" to get optimal results? I couldn't find any info on Subal's website. I am guessing that it's the EXR-65/4, but I am not 100% sure.
    Subal DP-SUP 10"
    Subal EXR-65-4
    Sebastian
  2. You probably need to tell us a bit more about the camera and lens that you are wanting to use.
    For instance with my Nikon D300 and Tokina 10-17 I use a 18mm extension. For the Nikon 10mm no extension at all.
    So it all depends..
    Paul C
  3. Hi Paul,
    I thought about using my Nikon D700 together with the Nikon 14-24mm. The Subal DP-SUP 10" is advertised as a dedicated port for the Nikon 14-24mm which I thought is best used with a full frame camera. But maybe I got this wrong and there are other camera/lens combinations that make sense with this special dome port? :P
    Sebastian
    So it all depends..
    Paul C
  4. Hi Sebastian,
    Ah sorry - hadn't realised that the dome was specific to the 14-24.
    To be fair it can't be that 'dedicated' or I guess it would come with the required extension!
    It is a hell of a big lump of glass though - good luck and may your baggage allowance remain large.
    The guy that would know if no one else jumps in here would be Ryan at Reef Photo - just drop him an email.
    Paul C
    Edited by PRC
  5. Hi Paul,
    I asked this question some time ago in this forum, but didn't get an answer so far:
    port extension Subal DP-SUP 10"
    It's just too bad that Subal's website isn't very helpful here. They only mention the DP-FE4 + EXR-66/4 as the (best?) setup for the Nikon 14-24mm. :) In my opinion it's not the job of the people running shops (like Ryan from Reefphoto) to find out what is the best setup for a certain lens. The manufactures of the housings and ports should do the job for their customers and put the info on their websites.
    Anyway, I am currently just calculating how much this would all cost - this DP-SUP is not cheap and - as you already pointed out - it's very heavy. :) But what else could I buy? A Nikon 16mm or the Sigma 15mm together with a fish eye dome port? For you guys shooting Nikon DX the choice seems to be easy: Tokina 10-17mm :P
    Sebastian
    Hi Sebastian,
    Paul C
  6. Well there are several respectable shooters with the D700 - Alex M for one, I know Alex has a Sigma 15 and a 8" port.
    Obviously that is a fisheye and the 14-24 seems to be a rectilinear - WA rectilinear lenses seem to be tougher to match to domes, witness the trouble the 12-24 on a DX has caused.
    Good luck again - my Subal 8" dome is heavy enough for me.
    Paul C
  7. Never tried the DP-SUP - so can't help. Alex
  8. Hi,
    Ryan just sent me an email - I hope he doesn't mind that I am posting the info here. He said that the best option he has tested is a EXR-65.
    Sebastian
    Hi Sebastian,
    Paul C
