Nikon View 1.5 + MAC OS 10.6 bugs
Started by Marcelo Krause ·
  1. I updated to Nikon View NX 1.5 on my Mac OS 10.6.1 and now all the menus are messed up. Every single function has the word IDS_... before it. It seems to be a common problem.
    I have not tested but here a solution proposed on flickr:
    "it can be fixed
    here is how i did it
    installed ViewNX v1.5
    dragged ViexNX v1.4 from my downloads folder on to the desktop
    downloaded application Pacifist
    for those that are not familiar with this application, it allows you to inspect inside the .dmg files and install single parts from the .dmg package.
    open pacifist and load the ViewNX v1.4 .dmg
    locate the folder named SubPackages
    then click on Contents of ViewNX_EN.pkg
    then click on Frameworks
    2 files
    Nkpluto.framework
    Zelkova6.framework
    then right click on or (ctrl click )Localizable.strings and select( install to default location)
    then do Folder OutputPlugins
    6 files
    Nkb_Export.framework
    Nkb_GeoTag.framework
    Nkb_Mail.framework
    Nkb_Print.framework
    Nkb_Slideshow.framework
    Nkb_Uploader.framework
    as above right click or (ctrl click) Localizable.strings and install to default location
    then select folder Resources
    then select folder English.lproj
    4 files
    Common .strings
    ErrorMessage.strings
    infoPlist.strings
    Localizable.strings
    few thats it, seems alot of work but it only takes a few minutes
    its actually taken me longer to write this, than it took me to do it
    works for me, hope it helps you "
    Best regards,
    Marcelo Krause
    www.marcelokrause.com
    Edited by Marcelo Krause
  2. Nikon should have this scripted and placed on their support site. Just what I needed. Thank you.
