What Diopter for Olympus PPO-E05 and 14-42
Started by globalmark ·
  1. Hi
    Just wondering what Choices I have for a Diopter for a 14-42 lens in a PPO-E05 (Pt-E06 Housing) I know from Garys Post that I can fit a Woody's Diopter by cutting my Port cap and fitting that Diopter inside ,
    However I was wondering what other choices are on the Market that maybe better or fit directly on the Olympus port etc.
    so any Info is appreciated.
    Thanks Mark
  2. Tell us a bit more, this seems to be an overall zoom lens, what do you want the diopter for? To use it as a macro? Do you want something that is removable underwater? If not, there are several close-up diopters that fit this lens (58mm) but once there you have to open the housing to remove them.
  3. Hi Mate
    I want a Wet diopter I can put on and Off underwater , for a Bit more Macro Use - I know it's not as Good as getting the 50mm Macro lens , But just to make the Lens a bit more versatile , There is a Guy "Gary Ramey" that has posted info on Using a Woody's Diopter by cutting the Port Cap and fitting this diopter in and works well , I was just wondering if there was other makes that are made to fit or Better for Macro use.
    Thanks Mark
