Nikon D50 Housing Help
Started by BreachProductions ·
  1. Looking to get a housing for my 2007 Nikon D50....Not looking to break the bank but looking for a stable setup I can rely on.....any info would be great......
  2. Considering that's a discontinued model, I would suggest trying to find a used Ikelite housing for it. Then when you upgrade you'll already have ports and lenses and just have to buy the housing body itself. Might be tough to find a housing new or used though since the D50 was only around for 2 years. Back in 2006 I ended up selling my D50 body and buying a D70 just because there were more housings available. I used the D70 for 2 years then upgraded the housing for my D300.
    Not saying anything is wrong with your D50, it was a good camera, still is... just wasn't around very long since Nikon retired it for the more inexpensive D40.
    Edited by johnspierce
  3. Considering that's a discontinued model, I would suggest trying to find a used Ikelite housing for it. Then when you upgrade you'll already have ports and lenses and just have to buy the housing body itself. Might be tough to find a housing new or used though since the D50 was only around for 2 years. Back in 2006 I ended up selling my D50 body and buying a D70 just because there were more housings available. I used the D70 for 2 years then upgraded the housing for my D300.
    Thanks John, Guess I'll try and find an old d50 housing or upgrade to a d70......thanks for the help there
  4. Hi ... Don't know if you'd be interested, but I have a D70 body that I'd be interested in trading for a D50. I have two Sea & Sea D50 housings and would like to acquire another D50 body as a back-up. The D70 is in excellent condition.
    Let me know if you're interested. Thanks, Greg
  5. Thanks John, Guess I'll try and find an old d50 housing or upgrade to a d70......thanks for the help there
    Just FYI, a D70 won't perform any better than your D50; they are very, very similar except the D50 is a bit lighter and it uses SD memory instead of Compact Flash. The only reason I switched was because I got a good deal on a used D70 housing. The D70 does have separate aperture and shutter speed control dials which make it a bit easier to use in manual mode underwater.
    JP
  6. Just FYI, a D70 won't perform any better than your D50; they are very, very similar except the D50 is a bit lighter and it uses SD memory instead of Compact Flash. The only reason I switched was because I got a good deal on a used D70 housing. The D70 does have separate aperture and shutter speed control dials which make it a bit easier to use in manual mode underwater.
    JP
    I found a brand new Ikelite housing on Ebay last dDec. for omly 650USD and it works great. Nice toi sea all the controls and if theres any leaking. The controls required a little bending to get right but the housing is great. Lots of ports available and Ikelite offers bullet proof customer service.
