5D finger trouble
Started by ErolE ·
5D finger trouble
  1. Hmmm I am having some niggling problems with firing my inon z-240 flashes in manual. I shoot by in large in manuel of Av with the strobes set to manual. Everything has been working great so far but now everytime I depress the tigger I get an annoying flashing icon in the top right of my menu screen. The icon is where the flash exposure compensation icon (lighting bolt with +/- beside it). But rather than this being displayed there is an icon that looks like a speedlight head with the +/- beside it. This is dialed in to -3 and flashes preventing the shutter from releasing. Now given that this icon isn t referenced in the manual and I don t know what it means I can t undial it.
    Any help would be appreciated...
    Thanks Erol
  2. For reference below is pasted Canon care explanation of what this icon means.
    It looks like perhaps there is a problem with the TTL circuitry. Once I figure it out I ll get back to you.
    Now that you have answered where the icon is located im going to tell
    you exactly what it means. This icon is displayed when the flash head is
    not firmly snapped into place, on an EOS Speedlite when you lower the
    flash head it snaps firmly into place, facing straight ahead, 90 degrees
    so to speak. If the head is depressed downward, past 90 degrees, the
    flash symbol flashes as a warning that it is not locked firmly into
    place. The negative 3 means that the exposure compensation is set to
    minus 3. The three flashing lines radiating out from the flash head
    means the flash head is active. When using a 580 ex II it is possible to
    disable the flash head and just use the infrared beam for autofocus
    assist,or when you just dont want the main flash tube to fire, there is
    also an 'active' symbol for that as well. Its shaped like a zigzagged
    arrow.
    So theres your answer. Thats what the symbol means, it flashes
    simultaneously on the flash panel as well.
    As to whats causing it? We have no clue since you are not using a Canon
    EOS Speedlite flash, its possible there is some communication issue
    between the camera and the flash. Its getting some false signal from the
    flash. There no telling at this point. I understand you have used it
    prior to this issue with no problems. However, there is nothing I can
    recommend to make it go away. Perhaps the makers of the Inon Strobes may
    be able to shed some light on this.
