Two new pics in the Mediterranean Sea
Started by mmb ·
  • 19Posts
  • 19Replies
  1. Two pics taken this week end in "El Toro Island" In Mallorca, Spain.
    Flabelina Affinis
    Nikon Coolpix 5000 en carcasa Ikelite con el flash Ikelite DS125
    Isla de El Toro, Mallorca.
    16.2mm 64mm (en 35mm)
    1/60 sec, f/7.1
    Poliqueto
    1/250 sec, f/7.1
    I have problems with the hosting of my web site. It´s out for a few days!
  2. post a couple instead, you can always remove them later.
  3. Attach a couple instead, you can always remove them later.
    I don´t understand you.
  4. If your web host is down you can post selected image files by depressing the browse button selecting images below 100kb press open, it will then appear in the browse slot. Then submit post.
    :D
  5. I think that now works fine!
  6. I try again!
  7. Excuse my ignorance! I can´t find the browse button! Where is It? (I never use this button)
  8. Hit "Reply"
    Then under the white box where you type, look for the words "File Attachments" That is where the "Browse" button is.
    Click on it and follow the directions to post a photo.
  9. I try, this is the first pic: Flabelina affinis:
  10. Thanks James.
    The second pic, Poliqueto:
  11. Wow! That was well worth the waiting for - Superb Nudibranch!
  12. Well done!
  13. Beautiful Mariano.............19mm? or native lens..........TTL or manual controller?
    Karl
  14. Now we're talking!!! Those are amazing shots!
  15. Wooow!
    The nudibranch picture is excellent!
  16. Thanks for the coments.
    Karl, I use the camera lens for this dive, without WA, the flash in TTL.
  17. Very nice! The Nudi looks a lot like what we in California ironically call a "Spanish Shawl" or Dancer.
  18. Mariano, when you switch between the 19mm and the native lens, do you also change ports? The native lens seems to work OK on land through the larger port, but I haven't tried it yet underwater. Sure would be convenient if you didn't have to switch ports.
    Karl
  19. when you switch between the 19mm and the native lens, do you also change ports?
    Hy Karl, I change the port to. I never try to use the 19 mm in the "flat port"
    Mariano
