FS: 5D Ikelite Housing w/DS200 Strobe and ports
Started by clespron ·
  1. 5D Housing:
    The heavy duty thick wall dSLR housing is molded of corrosion free clear polycarbonate, features full capabilities, and operates safely to 200 feet.
    The #6871.05 housing includes conversion circuitry that provides eTTL2 compatibility for current model Ikelite DS SubStrobes. The circuitry includes two f/stop over and under compensation in half-stop increments, and eight manual power settings in half-stop increments by simply pushing a button.
    Digital Substrobe DS200 Set:
    Package includes #4085.26 SA-125 Arm and 1.5 hour Smart Charger #3944.60 with Ikelite TTL sync cord.
    S p e c i f i c a t i o n s
    Energy Rating....... 200 wat-sec
    Recycle Time ....... 1.6 sec
    Angle of Coverage....... 100 degrees....... 110 degrees with diffuser
    Guide # (ISO 100) feet ....... 76 surface - 38 underwater
    Guide # meters....... 24 surface - 12 underwater
    Color Temperature....... 4800 degrees Kelvin
    Full Power Flashes....... 160 flashes per full charge
    Firing Modes....... TTL, Full, 3 fractional powers
    Modeling Light....... Built-in Halogen
    Battery Pack....... NiMH module
    Weight....... 1.8 kg (3.9 lb)
    Size....... 11.5 cm dia x 19 cm....... 4.5" dia x 7.5"
    Depth Rating ....... 90m - 300 feet
    I moved away from the water and need money. Everything is in good. I will even throw in a 15mm port and 100mm port into the purchase.
    Asking $1,700 for everything.
    Edited by clespron
  2. sold?
