Z240(type 4) strobe and Maha PowerX batteries
Started by marcw ·
  1. Will Z240(type 4) strobe and Maha PowerX batteries work together, or should I buy the recommend enloop batteries? I have many powerx batteries, should I switch? Is there any issue with these batteries and the strobe?
    thanks
    BTW, not IMEDION, the older 2700mha batteries
    Edited by marcw
  2. Will Z240(type 4) strobe and Maha PowerX batteries work together, or should I buy the recommend enloop batteries? I have many powerx batteries, should I switch? Is there any issue with these batteries and the strobe?
    thanks
    They will work but with some very low probability of an overheating/gas pressurization event that might lead to a leak. I used to use them all the time with never an issue. However in testing the low internal discharge batteries, you get quite a few more strobe flashes with the low discharge batteries even though the labeled capacity is less. I would vote for the eneloop types.
    Bill
  3. any remedation on IMEDION or eneloops?
  4. any remedation on IMEDION or eneloops?
    I have been testing batteries extensively for answering just that question. I bought all of the low internal discharge batteries that Thomas Distributing has. The winner by a bit was the Kodak version, Eneloop second, the rest were all about the same.
    Bill
