Dual S&S 110a for TTL with compact digital camera
Started by Jim VG ·
  1. I just purchased a second Sea & Sea 110a for use with my OlySP550 compact digital camera. My TTL works great with a single strobe using an optical cable, Stobe settings (TTL mode, full power, slave on)....and camera using internal flash with preflash....Using a second strobe....does any one know the best config....
    Should I run a second optical cable from the camrea und use the same config?
    Should I run a second optical cable from the 1st strobe to the second strobe and use the same config?
    Should I run a second optical cable from the 1st strobe to the second strobe and use different configs?
    If anyone is using this set up and can let me know it would be greatly appreciated....
