CIS Epson Inks for R1800 Printer
Started by deepsea ·
  1. HI
    I am just wondering if anyone here has used the continuous ink system for the Epson R1800 and if it was good, inks lasted etc.
    Many thanks
    Karen
  2. I have been using the Lyson CIS on my Epson Stylus Photo 2200 / 2100 for many years without problems. It is available for the R1800 http://www.lyson.com/community/news.asp?id=3
    Now if you change ink system you will need to match your printer profile with the ink + paper combination that you choose to use. There are some of these available on the Lyson web site, but if you wish to use other combinations you may have to create them yourself (or pay to get them done).
    The other thing to be generally aware of is that there are basically two types of ink - dye based and pigment based. If you are looking for longevity in your prints you should use pigment based inks (I'm sure we have all seen faded pictures people have printed on their printers at home - they mainly use dye based ink). Not all photo papers will take pigment based ink so you need to take care there. I use Lyson cave paint ink (although I think they renamed it not so long ago).
    Hope this helps.
  3. HI
    Many thanks
    Karen
    I have used the Niagara system with pigment inks on an R800 (same technology) with no problems and quite good matching with Epson papers and Epson ink profiles
    Bill
  4. Thanks very much for your replies and all the information, will check all these systems out.
    Have a great weekend
    Karen
