External Macro Diopter
Started by JohnnyQuest ·
  • 9Posts
  • 9Replies
  1. I did a search and couldn't really find much. Does anyone make an external magnifier that can be easily attached and removed UW like an external color-correction filter? If not, is there some physical reason that this wolud not work? I've used a magnifying glass UW and it works.
    Do any housings have an internal diopter that can be rotated into place for a macro shot and then rotated out for wide-angle shooting?
    Thanks.
  2. A fair few of the housing manufacturers have flip diopter, off the top of my head Gates do and L&M do, I'm sure there are others.
    Not too sure about external diopters though, I've never seen one.
  3.
    Fantastic! Thanks a lot Lightydo. Do you have any experience with how well this works?
    When I get my next housing, I'll look for the flip in/out option. Thanks Johnny Shaw.
  4. Inon has some macro lenses. They can be stacked together.
    On my previous sd system, I've used to have terrestrial diopters mounted underwater on the M67 port. +10 and +4 . Worked okay. I am however sure, it would work badly on HD...
  5. Century / Schneider Optics Achromatic Diopters are the best you can get but not external.
    I can't imagine anything working with any level of acceptance for image quality given that the optics would have trying to look through the water that would be trapped between the external plane of the port and the filter.
    Methinks not a good idea.
    0.2c
    Mark.
  6. Has anyone had any experience with the L&M flip macro? Works with a 90 and 110 port or just the flat port?
  7. Has anyone had any experience with the L&M flip macro? Works with a 90 and 110 port or just the flat port?
    I have one that works with my 80 degree port on the Bluefin FX1 and it's great. It's in and out all the time on a "general" dive. I also had the one that works with the flat port and I didn't like it at all (and just sold it for peanuts). I use the Century achromatic +3.5 for macro work which is much better but sadly not flippable.
  8. Same here I've got the Century +3.5 and it is excellent, but it is screw in so you are then shooting macro for the whole dive. A couple of times when I've been using it something bigger has come along or I wanted to be able to get some WA shots and I've regretted that I didn't have the ability to flip it out of the way (I've found it very hard to pull focus with it on if you want to shoot WA with it). I've also used an external Inon wet diopter and there is just no comparison between the two in quality.
    Cheers, Simon
    Edited by SimonSpear
