Canon S45 + Sea&Sea YS90DX
Started by Anthony ·
  1. I just bought a YS90DX to complement my S45.
    I was wondering if anyone could give me a few tips before I hit the water.
    Mainly I was wondering now that I'm using an external strobe, what mode I should
    use my camera in? I normally have it on P, but will this cause my shots to be over-exposed?
    Any tips would be much appreciated!
    Thanks.
  2. Hi Anthony
    Normally the camera is fireing a pre-flash to measure the object. If the YS-90 also fires at the pre-flash everything is fine. Otherwise you have to reconfigure the YS-90. I had this problem with my YS-60. For me i had to open the YS-60 and reassemble some cables. But the YS90 should be capable of fireing 2 flashes within some ms.
  3. ... OR you could disable the preflash from the S45 camera.
    I have a S50 and I shoot in C mode and what I did is that I have the flash always on and shoot in Av mode.
    Vlad
  4. Few questions...
    1. Should I set the ISO to auto or a manual setting? (This can't be altered once the camera is in the housing)
    2. What is the best mode to shoot with? Aperature priority, Shutter priority, or P?
    3. Because I dont have TTL, how do I adjust the strobe output to my camera settings?
    Sorry for all the annoying questions, but this is all new to me. I'm trying to find a bit of literature.
  5. Hello,
    Here is what I think
    >>>>I think you should set it to 50 or 100.
    >>>It depends. I shoot in Av but I can see why you would want to set the time and then let the aperture be set automaticaly. Definitely not P
    >>>>You don't!
    You will have to try settings.
    Although ... I think if your strobe can take the preflash, you could do TTL and everything should be OK.
    My strobe is crappy so I can't even set the power on it. I usualy set it to about 5 for aperture and then the time is usualy 1/60 or so.
    Vlad
  6. Thanks for the advice Vlad. Will try it out
  7. ... OR you could disable the preflash from the S45 camera.
    Vlad
    Hi Vlad
    How do you disable the preflash mode of S50. I have a S50 +90DX. The flash sometimes cannot synchronize with the camera even I have set the 90DX to PRE position.
    Daniel
  8. I don't have an S50 but you can disable the pre-flash by setting the 'Flash Adjust' to 'Manual'. The pre-flash is automatically disabled in M mode. You can then set the Flash Output in 3 steps - select the lowest setting that will trigger the YS-90DX. This will save batteries and help the camera's flash to recycle faster so you can take the next shot quicker. Don't forget to set the YS-90Dx to 'On' instead of 'Pre'.
