Mini DV4.3 to HD 16.9
Started by wagsy ·
  1. Howdy all
    Well after looking at all my old Mini DV 4.3 tapes sitting around here, I decided to have a go at upscaling to 16.9 and even HD size.
    I know there are a few commercial products around but this is what I came up with using Virturaldub, an open source free encoder.
    It can do many things apart from just this.
    Once you make the clip just import it into your NLE and away you go.
    How I did it can be found here
    Video clips...
  2. GREAT !!! ...
    I've just spent days sifting through my HDV and EX1 footage now I find out I can dust off the old Mini DV stock and start looking through that as well ...
    When will it ever end !!! :D
    Cheers Wags ...
    Dive safe
    DeanB
  3. As Wagsy said, there are several softwares that do this, Red Giant's Instant HD Advanced comes to mind(http://www.kenstone.net/fcp_homepage/magic_bullets_instant_hd.html
    There are others and while some use more advanced algorithms than others, they all work by mulit vector analysis, some of the subject(not so good) some of the fore or background. Scaling is the main issue here as anything scaled above 103% will result in some softening of the image and resolution loss. I stopped Wags clips towards the beginning as the octo was rising and it is plain to see that some of the image is lost and there is a touch of softening. I think the images here are very good but one using this type should use it sparingly, for a clip that was so good, you must use it in the project. You wouldn't want to upscale all your old SD footage and make a program out of it, it would be very noticiable. It is great to have though for those once in a lifetime clips from the old days.
    Edited by steve
  4. Hi Steve
    Yes its abit like trying to make a image larger than it really is in Photoshop, never the same as the original quality.
    Its a work around the will allow us to use certain clips for stuff for sure.
    Trouble is we are all use to looking a HD stuff now so can pick it out.
    The way these computer screens are going, maybe we can just shoot the 4.3 clip running on the screen with our 16.9 cameras. :D
    Deano, you had better hurry up and do it before you become a daddy......
    EDIT
    Just loaded up an upscaled 16.9 version of my old Ningaloo DV4.3 clip.
    Edited by wagsy
