Nikon L1 Problems with Ikelite Flash
Started by txdiverdude ·
  1. I have a Nikon L1 camera that I use with an Ikelite housing and DS50 strobe. However, the flash pictures seem to almost always be grossly overexposed or doesn't strobe. Have had strobe "fixed" by Ikelite but no improvement. Uses the EV-Controller Slave Sensor since there is no sync cord connection on the camera. Has anyone else seen same problem or have a solution?
  2. Ok I will take a go.
    Are you always getting a full dump from the flash ?
    The EV controller should dial the flash right down to almost nothing, if it is not then the controller is suspect.
    Can you shoot the camera in manual mode - or is it auto everything ? (I am not familiar with it myself).
    Another option is that the pre-flash is getting in the way - if the DS50 is set up to ignore the first (pre) flash then dumps on the second (main) flash then the exposure the camera calculates based on the pre flash would cause significant over exposure.
    Paul C
