Nikon 105 VR help - Aquatica port ring.
Started by Alastair ·
  1. i had a bit of bad news the other week as someone managed to lift my camera bag......
    unfortunately they managed to get away with all my tools and spares but most dissapointingly my trusty old 105mm macro..
    but on the upside i have management permission to get a replacement ^_^:)
    And this leads to my question..
    I have an Aquatica housing setup and the port extension ring for the old 105 is it the same as for the new 105 or is there a difference in port ring size (length)?
    Thanks in advance for the help...
    AM
  2. You need 18453 for the new, not 18462, which is for the old.
  3. cheers..
  4. i think you'll be fine, i actually use a shorter extension ring (not sure exact one, about a inch long) for the new 105mm as it doesn't extend when focusing. gets it super close to the port but that's a good thing. it should still work fine with the old longer one too.
  5. Hi Allastair, sorry for the response delay, I was at the Paris dive show (huge show BTW) and i'm just back, you will be fine with your current extension, send me a PM at jean@aquatica.ca and I will send you a PDF chart of our extensions dimensions, not only does it confirm which one you have but also will help in selecting future one should you explore macrophotography with teleconverter, internal diopter etc.
