TTL not TTL-ing
Started by mrginhop ·
TTL not TTL-ing
  1. I recently purchased a S&S DX housing for the Nikon D50. It came with the TTL bulkhead & converter. I was told it would work fine with my S&S DX90 & 120 Duo flashes to enable me to get TTL. It doesn't. Works fine in manual mode but does not seem to work in TTL. Flashes are going off at full power. What am I missing here?
  2. You have to make sure you have your camera settings correct according to the manual. Without more details on your settings, it's difficult to trouble shoot.
    Usually the best way to test is to mess with the exposure compensation to see if the power is varying.
  3. I figured out what the problem was. Turns out the flash setting was on red eye. I missed that somehow. Duhh. Works great now.
