Lens Choices
Started by JohnRLewis ·
Lens Choices
  1. I'm saving up cash for a Nikon D100 setup, researching while I wait. This will be my first SLR, so I dont have any experience on which lens can do what.
    For my first lens, I might get the 60mm, but I wont be geting the 12-24 or 17-35 yet. One reason is cost, another is that I am fascinated by macro.
    I am thinking about a mid range zoom lens with macro capability. I've heard opinions that this is not the best choice. Not wide enough for wide angle work, and cant get close enough for macro. But this sort of lens gets recomended as a first topside lens. Please help me out by answering some specific questions below.
    Assume I have the D100 with the 60mm Macro lens that seems to come highly recomended on this forum. Also assume a standard flat port.
    * How close could I get to my subject?
    * How big can I make a very small subject appear?
    * If I took a photo of a large subject at a specific distance, say, 10ft, how much of that subject would I capture? (in other words, when that big palegic swims by, am I going to get a decent photo?)
    Assume I use the 28-105mm f/3.5-4.5D Macro with a dome port and a +4 diopter close up lens.
    * Using this lens, how close can I get to my subject for macro work? (with and without the +4 diopter)
    * How big can I make a very small subject appear? (with and without the +4 diopter)
    * With the lens zoomed out to 28mm, and I were to take a photo of a large subject at a specific distance, say, 10ft, how much of that subject would I capture?
    Is there some formula that I can apply to help me answer these types of questions for any lens?
  2. * How close could I get to my subject?
    Really close. The port will get very close to the subject. The min focus distance is 8.75" and the lens is 2.9". About 5" from the end of the lens.
    A quarter will fill up most of your frame and get some of it chopped off the top and bottom.
    You can get the whole subject, but the photo will be far from decent. Ten feet is far away, as in no strobe light. You would have to open up the aperture to get even a remotely decent exposure. It will lack color and depth of field.
    You can get very nice fish portraits from a reasonable distance, say 3-4ft. If the big guy comes by, you can still get a decent shot, just not a full body shot. I've photo'd many a barracuda with the 105mm lens, just not the entire fish.
    The min focus distance is 1.7'. The repo rate is 1:2.74 w/o diopter, not very good, but still macro range on the D100. The diopter will get you closer. Remember, the dome will be several inches away from the end of the lens, which uses up a lot of the working space. Getting domes close to macro subjects can be problematic as can positioning your strobes for macro while using a dome port. I shoot the 17-35mm behind the dome. It is the equivalent of 52.5mm with a minimum focus distance of 12". So I can get the dome almost right up to the subject.
    While you can do some macro, this setup you are talking about is far from optimal.
    Well, you can't make it bigger than it is. How big is big?
    Plenty, depending on how large the subject is.
    This was taken at 35mm I believe, as was the next one.
    "Is there some formula that I can apply to help me answer these types of questions for any lens?"
    Of course, but I don't do math anymore. It gets in the way of good photography.
    Define what it is you want to do. Choose the best tool for that job. If you have another job, get the best tool for that job. If you are only going to get one lens to start, get the 60mm and work on macro and fish portraits until you perfect it. If you can afford a second lens and need something more versatile for above water shooting, then get the 28-105mm or better yet the 24-85mm G lens or 18-36mm. You can any of those for wide angle work underwater. Not as wide as some would like, but pretty workable.
    I believe a common mistake, especially new photographers, is to want to go too wide too soon. The result is often poor compositions that are too wide, or excessive cropping. (Cropping can not always cure poor framing) I spent years taking bad photos with the 20mm. As soon as I switched to the 24mm, the quality of the composition improved dramatically. Only then did I start moving wider again.
  3. For a "mid-range macro-zoom, try the Nikkor 24-85 AFS-G (f3.5)
    It is cheap, focuses close, and is very sharp. You can shoot it behind a flat port w/ the D100 as it is an effective 36-130mm field of view.
    HTH
  4. For a "mid-range macro-zoom, try the Nikkor 24-85 AFS-G (f3.5)
    Which housing supports that lens? I was looking at the Ikelite, but they do not support that lens. The other two choices I was considering were Sea and Sea, and Aquatica. But I cannot make sense of their websites as far as which lenses they support.
  5. Yes. It is supported by Aquatica and Nexus. I'm sure it will fit in the Sea and Sea housing, but I don't know if they can supply the zoom gear.
    James Wiseman
  6. * How close could I get to my subject?
    Scorpio fish is correct that you can get very close with the 60mm and macro port. However, it can be a little tricky to get light on the subject when you're that close. If you really interested in serious macro, the 105mm is a superb lens, and you have more working room to get the strobe(s) in there. Also, you can stay outside the "threat zone" of many small critters.
  7. Does anyone add close up lenses to fixed focal length lenses? Wouldn't that allow you a little more room to get the strobes positioned?
  8. Subal also supports the 24-85 zoom. It takes a 40 mm extension ring and a +4 diopter with the FE2 dome.
    I tried this lens with my film housing with the SWB port a few years ago, and didn't have much good to say about that combination. Might be better with the FE2. I do use this lens a lot above water - it's become my standard land camera lens for trips, both for 35 mm film SLR and the Fuji S2.
    As for using close-up diopters with prime lenses, I always use a diopter with both the 20 mm and 28 mm prime lenses. But whether a diopter is required - and which one - is primarily a function of the dome port optics. In general, larger diameter domes don't require as much diopter magnfication as smaller diameter ports. I need a +3/+4 diopter for almost any lense used with the SWB port, but only +2 with the FE2.
    Check the manufacturer's recommendations.
