Sea & Sea YS200 Strobes with E/O, New Aquatica Ports, More!
Started by mo2vation ·
  1. Hi all
    I've secured the items of a former professional photographer. His shots have appeared in National Geographic, Nature and nearly every outdoor and underwater publication - and I've been secured to sell off some of his gear.
    I've listed it here with photos. I don't have prices for it yet. Even though I am a UW photographer myself, I don't use Sea&Sea and Aquatica gear, so I'm still gathering market prices for most of this. If I've mis-identified any of this stuff, please, PLEASE send me a PM so I can correct the ad. Thanks for your assistance.
    All photos are of the actual stuff for sale. No harvested or manufacturer-provided photos. The stuff does look this good.
    Please send questions to ken@divematrix.com.
    Here's the stuff:
    Thanks!
    -Ken
    Here's the list:
    4ea - Sea & Sea YS-200 Strobes.
    You've seen these giants - they're in very good to excellent condition. I have TWO battery packs for each, and one charger for each. I have 6 chargers available - so two of these will come with two chargers (one for each battery pack.) The cables attached to the strobes are E/O cables. There are four of these available.
    2ea NEW Sea & Sea YS-200 Battery Chargers
    These chargers have never been used, never opened, never taken out of the house. I have two available. $60 each, delivered to any address in the US
    2ea - Aquatica to E/O Cord
    One end connects to the Aquatica Port, the other is the E/O end for the E/O strobe cable. I have two of these available. I've included a close up shot of the housing-end of the cable. These look like they've never been in the water. They are clean, clean.
    2ea - E/O Y-Adapter
    These allow you to plug two E/O devices (like the strobes) into one E/O fitting. These fit into the Aquatica to E/O, above. These look like they've never been in the water, as they are spotless.
    Sea & Sea Strobe Arm
    This is an aluminum arm with a 1" ball on one end, and a Q/R fitting on the other. This arm is 12" long.
    This is an aluminum arm with a 1" ball on one end, and a blade fitting that works with a Sea & Sea (and several other manufacturers') Strobe on the other. This arm is 12" long.
    2ea - Aquatica / TLC 6" Strobe Arm
    These arms are in near-new condition. There is a 1" ball on one end, and a blade fitting on the other end that will work with Sea & Sea (and other) strobes. There are two of these available.
    Aquatica / TLC 12" Strobe Arm
    This arm has a 1" ball on one end, and a slot mount on the other - for mounting it to a variety of housings. This arm is in near-new condition.
    This arm has a 1" ball on both ends. This arm is in near-new condition.
    More stuff below. Apparently I've reached the limit of photos I can insert into one post.
    -K
    Edited by mo2vation
