What size Alum Key/Hex Wrench for Sea-sea fibre optical cable ends
Started by globalmark ·
  1. Hi
    Does any one know what size Hex wrench/Alum Key is needed to unscrew the Grub screw in the end of a Older style Sea-sea Optical Fibre cable , as Had to cut cable as was damaged and now need to re attach the end.
    from the looks of it the size must be 0.75mm-1mm or somewhere around that size , it is very tiny thats for sure .
    if someone knows or knows a Contact email for Sea-sea that I could ask would be great
    Mark
    Sorry don't know model number of Cable but is 7 years old Black all over inc Ends , ha one 90˚ bend in one end with small blue o-ring on each end.And held to cable with Hex Head grub screw.
  2. Hi
    Mark
    0.7 or 0.9 (My old cable had 0.7 mm) You can get them from McMaster for 15 cents each
    BVA
