Hey I just bought the canon hv40 and I put my order in for the ike housing for it. Now my questions is should I buy the wide angle adapter or a light for it, I can't afford the $800 one so I would have to go with the cheaper ike wide angle, Or should I buy the 300 dollar single light? Or should I just dive with the housing and white balence at depth? I"m going to Utilla and Roatan in April. So any suggestions would be great.
Lens, Light, or should I just dive with the new Housing
Started by Sub Nate ·
- 5Posts
- 5Replies
Hi there.
Congrats on you little setup.
I would suggest you go for a wide angle first before a light.
Put a URPRO filter on it and while balance at depth to get nice colors if you can.
It will make you shots much better, then move onto a light later.
Hi there.
Hey I was wondering do you put the filter on the camera or the housing, Probably the wide angle lens if I get that, do you know anyone using the w20 ike wide angle or do you have any recomendations for a wide angle, I want to stay in the $300 dollar range. thanks for any help, also what settings would you suggest for a newb.
Housing:Hey I was wondering do you put the filter on the camera or the housing
Note sure if the included filter will work with a w/a lens though. Might ask Ikelite: ikelite@ikelite.com for sales supportRemovable External UR/Pro Filter -
Or you could probably fit a magic filter in front of the camera lens inside the housing.
