I am asking $900 or best offer for the system. US sales only.
Shipping method and cost: UPS ground; $32 above the selling price.
Payment method: PayPal
The system was purchased approximately two years ago for $2000. This is a very nice crossover( one step above a point and shoot) camera with manual and auto mode settings. It also shoots very nice video. The original camera tray has been replaced with a Fisheye Digicam tray with flexible strobe arms. This makes positioning the strobe extremely easy. The system includes the wide angle lens with carrying bracket and an YS27 strobe. The wide angle lens is swappable underwater and its carrying bracket easily attaches to the tray via zip ties. The camera is equally good at taking macro and wide angle photos. The camera manual mode provides the same exposure and depth of field control as a DSLR without the several thousands of dollars equipment price tag. This is an excellent system for someone who would like to start to explore underwater photograph or upgrade from a simple point and shoot. This system includes everything you need to start taking underwater pictures; there is no need to be purchase additional items before you start using this system underwater.
I am selling the system because I decided it is time to take my DSLR underwater.
The system is two years old but is still in good shape. There is a very small scratch on the wide angle lens but it is not visible on the pictures. There is also a tear in the case’s factory cut foam but this defect it does not impact the integrity of the case.
Detailed information about the system can be found at: http://www.seaandsea.com/
Additional dive photos can be found at:
http://www.flickr.com/photos/32492676@N05/...57623325465601/
This system includes the following:
1 Sea&Sea 1G 10.1 Mega pixel camera that shoots in RAW or jpg mode
3 Rechargeable batteries
1 Battery charger
1 SD card size 1G
1 Camera Carrying Case (for land use)
1 DX-1G underwater housing
1 LCD sun visor
1 Spare housing gasket
1 YS27 strobe
1 Optical slave cable
1 Fisheye Digital tray with ezloc flexible arms and Sea&Sea mounting bracket
1 Wide angle detachable lens with carrying bracket
1 Pelican carrying case with factory cut foam
1 instruction booklet for camera and housing
1 Sea&Sea grease tube
1G Camera Specification
CCD CCD Effective 10.01 million pixels (total 10.30 million pixels), 1/1.75-inch primary-color CCD
Lens Focal length: f=5.1-15.3mm (35mm camera equivalent, 24-72mm) Aperture (F value): F2.5 (wide) - F4.4 (tele) Lens construction: 11 elements in 7 groups Number of aperture blades: 7
Vibration correction function CCD shift method
Zoom Optical: 3x (35mm camera equivalent 24-72mm) Digital: 4x (Maximum 12x when combined with optical)
Shooting distance Approx. 30cm / 12inch - infinity from lens tip (wide and tele)
Macro shooting distance Approx. 1cm / 0.4inch - infinity from lens tip (wide), approx. 4cm / 1.6inch - infinity from lens tip (tele) Approx. 1cm / 0.4inch - infinity from lens tip (zoom macro mode)
Shutter speed [still image] 180, 120, 60, 30, 15, 8, 4, 2, 1 - 1/2000sec [Movie] 1/30 - 1/2000sec
Pixels [still image] 3648x2736, 3648x2432, 2736x2736, 3264x2448, 2592x1944, 2048x1536, 1280x960, 640x480 [Text] 3648x2736, 2048x1536 [Movie] 640x480, 320x240
Picture mode F (Fine) / N (Normal) / RAW
ISO sensitivity (standard output sensitivity) AUTO, AUTO-HI, ISO80, ISO100, ISO200, ISO400, ISO800, ISO1600
Flash FAUTO, Red-eye reduction, On, Slow synchro, Soft flash, Off Flash range: Approx. 0.2m / 8inch - 5.0m / 200inch (wide), 0.15m / 6inch - 3.0m / 120inch (tele)
Focus Multi AF, Spot AF, Manual focus, Snap (fixed focus), Infinity
Exposure adjustment TTL-CCD metering method (AE lock possible): Multi light metering (256 segments), Center-weighted light metering, Spot metering
Exposure compensation cManual exposure compensation +2.0EV - -2.0 (1/3EV steps) Auto bracket function (-0.3EV, ±0, +0.3EV / -0.5EV, ±0, +0.5EV
White balance balance Auto, Outdoor, Cloudy, Incandescent, Fluorescent, Manual, White balance bracket
Memory type SD memory card (32,64,128,256,512MB,1GB,2GB), SDHC memory card (4GB), Multi-media card, Internal memory (26MB)
Storage capacity (No. of pictures) (Internal 26MB memory)*1 [still image] 3648x2736 (Raw: 1, F: 6, N: 11), 3648x2432 (Raw: 1, F: 7, N: 13), 2736x2736 (F: 8), 3264x2448 (N: 14), 2592x1944 (N: 22), 2048x1536 (N: 35),1280x960 (N: 62), 640x480 (N: 276)
Storage capacity (time) (Internal 26MB memory) *1 [Movie] 640x480: 30frames/sec. (12sec.), 15frames/sec. (24sec.) 320x240: 30frames/sec. (39sec.), 15frames/sec. (1min.16sec.)
Storage data capacity(Sizes are approximate) [still image] 3648x2736 (RAW: 14.4MB/screen, F: 3.61MB/screen, N: 2.07MB/screen), 3648x2432 (RAW: 12.8MB/screen, F: 3.21MB/screen, N: 1.85MB/screen), 2736x2736 (F: 2.71MB/screen), 3264x2448 (N: 1.67MB/ screen), 2592x1944 (N: 1.06MB/screen), 2048x1536 (N: 672KB/screen), 1280x960 (N: 356KB/screen), 640x480 (N: 83KB/screen)
Recording modes Still image modes (Still, CONT, S-CONT, M-CONT) / Program shift / Aperture priority / Manual exposure mode / Scene modes (Portrait / SEA&SEA / Landscape / Nightscape / Skew correction / Text / Zoom macro / High sensitivity) / Movie mode / My setting 1 & 2
Recording format [still picture] JPEG (Exif ver.2.21), RAW (DNG)[Movie] AVI (Open DML Motion JPEG format compliant)[sound] WAV (Exif ver.2.21 μ law)
LCD monitor display 2.5-inch transparent amorphous silicon TFT LCD (approx. 230,000 pixels)
Self timer Operation time: approx. 10sec. / approx. 2sec.
Interval timer Shooting interval: 5sec. - 3 hours (5sec. steps)
PC interface USB2.0 Hi-Speed (mini-B cable), choice of original or Mass storage driver
AV interface Audio OUT / Video OUT
Video signal format NTSC / PAL
Dimensions (WxHxD) 111.6x58.0x25.0mm / 4.4x2.3x1inch (excluding projecting parts)
Weight Approx. 220g / 7.7oz (excluding batteries, SD memory card and strap)
Battery Rechargeable battery (DB-60) x 1, optional AC adaptor (AC4c), AAA battery (alkaline / oxyride / Ni-MH) x 2
DX-1G Housing Specifications
[Construction]Polycarbonate
[Depth rating]55m / 180ft
[Dimensions (WxHxD)]158x109x109mm / 6.3x4.4x4.4inch
[Weight]Approx. 510g / 17.9oz (excluding hand strap)
[underwater weight]Approx. -110g / -3.9oz
