D200 Aquatica Housing, D200
Started by scorpio_fish ·
  1. Housing, no ports, no view finder. Need rubber ends on two levers and an adjustment to the front command dial control. Should probably get a new body o-ring. $1250
    Aquaview viewfinder. Looks a little rough. Has around 300 dives on it. $500
    D200 $850
    D200 $800
    Both went through a full Nikon servicing for $250 each about six months ago. The cheaper one has a CF door lever that sticks. When you push it to open the CF door, you have to push it back. Otherwise everything is fine.
  2. Housing, no ports, no view finder. Need rubber ends on two levers and an adjustment to the front command dial control. Should probably get a new body o-ring. $1250
    D200 $850
    D200 $800
    DM
  3. Housing, no ports, no view finder. Need rubber ends on two levers and an adjustment to the front command dial control. Should probably get a new body o-ring. $1250
    D200 $850
    D200 $800
  4. Sorry, I've been gone for a while.
    All are still available. Pictures to be available tomorrow.
  5. Hi do you still have the Aquatica D200 Housing? I might be interested. Thanks
  6. Yes, everything is still available.
