Aquatica 6" Dome
Started by Marco P ·
Aquatica 6" Dome
  1. Hi!
    I have a Canon 5D and use a Aquatica housing. I´m thinking about getting the 6" dome for my 15mm fisheye lens to make it easier when shooting CFWA, how will the 6" dome perform? I already have the 8" dome and that is excellent, but a bit large for CFWA. I usually shoot fisheye at f8-f11. If it works, do I have to use the 6" dome shade?
    /Marco
  2. That 6mm dome works well with a Nikon D200 and 10mm lens with x1.4 Kenko convertor. I can't speak for your Canon setup.
    The downside of this technique has been brought up elsewhere, but it's worth repeating. You don't get the 'wide angle macro' effect unless you get really close to the subject; only a few subjects will tolerate you putting a dome to within a few inches of their noses. If you don't get the right subjects, you're left with what is basically a crap wide-angle lens. Nevertheless, this style of shooting can garner unique pictures.
    Good luck!
  3. Ok, thanks for your answer. I think I just continue shooting with my 8" dome, it´s a cheaper solution too...
