Shrimps ID help!
Started by Tigershark ·
Shrimps ID help!
  1. Is it possible to aid in the identification of these three shrimp?
    I apologize for the quality of the photos, are crop, blurry and badly lit.
    Photos taken at Walea in Indonesia.
    Shrimp 1
    Shrimp 2
    Shrimp 3
    Thanks in advance,
    Tigershark
  2. The first one is a hippolytid, the third is commonly identified as Hippolyte commensalis. 2nd one I haven't seen before. There are two other crustaceans in the 2nd shot - right below the shrimp is what seems to be a cumacean and another pod at about 10:30. Would you mind cropping & enlarging the 2 others? I'd like to have a better look at them.
  3. Hi Leslie,
    Thanks for the help.
    The definition is not very good, but it was the best I could in these crops.
    Hope that helps.
  4. Thanks! The first is definitely a cumacean, the second is a copepod with 2 clumps of eggs attached to its posterior, and the third is a femlae caprellid amphipod (commonly known as skeleton shrimp). The caprellid is bent backwards; its hind legs are at the top, the head with 1 yellow eye showing is at the bottom, and inbetween is the brood pouch with eggs.
    Cumaceans are small crustaceans with a very characteristic body shape. The anterior part of the body is large compared to the abdomen which is reduced to a jointed cyclinder. See http://www.flickr.com/photos/olafial/211822907/ or
    http://eol.org/pages/39771
