Lion fish portrait
Started by gillie ·
  • 11Posts
  • 11Replies
Lion fish portrait
  1. IMG-0811a.jpgHi All, this one was taken at Candi dasa in Bali. Canon G9 and epoque 2x macro lens on night dive. Single Intova IS2000 slave strobe.
    Comments appreciated.
  2. It's either VERY over-exposed or you forgot to add the image!
  3. It's either VERY over-exposed or you forgot to add the image!
    "HELP" i copied in the URL for the image but where is it??? first time poster :)
  4. {img}http://images.gillie1.multiply.com/image/2/photos/19/600x600/1/IMG-0811a.jpg{/img} Hi All, this one was taken at Candi dasa in Bali. Canon G9 and epoque 2x macro lens on night dive. Single Intova IS2000 slave strobe.
    brackets changed to let it be seen
    You've done it right but your address must be wrong for some reason, I cannot access your photos due to limited internet access, I saw your home page, is it the lionfish portrait on there? http://images.gillie1.multiply.com
  5. brackets changed to let it be seen
    Yes thats where it is, thanks.
  6. Images are added with square brackets, so [ img ] instead of { img }. (remove the spaces)
    i attempted to embedd the image just above this using the code
    [img=http://images.gillie1.multiply.com/image/2/photos/19/600x600/1/IMG-0811a.jpg]
    it appears to me that the images are not able to be linked to outside sites, the embed code it gives is as follows and the image doesn't show from it
    http://images.gillie1.multiply.com/image/2/photos/19/500x500/1/IMG-0811a.jpg?et=%2Bcgm%2CInTfdOxsQhAow9XrQ&nmid=319991304
    you can create links to it thought such as
    Lion Fish Image
    using the code
    [url=http://gillie1.multiply.com/photos/album/19/Bali_Candi_Dasa_2010#1>IMG_0811a.jpg]Lion Fish Image[/url]
    Edited by Giles
  8. i attempted to embedd the image just above this using the code
    Many thanks for the help, can you recomend another site to store images?
    Edited by Giles
  9. www.tinypic.com is very quick and easy, you dont even need to set up an account..more to the point I can use it at work and see the pics at work!!
  10. Hi,
    Quite a few folks use Flickr
    It is pretty easy to link to your pictures on this forum with it-see the thread here
    It is free, and very easy to upload to!
    Don't forget to join the Wetpixel Flickr group as well
    Adam
