Canon 100 mm w/ TC + Diopter
Started by danielstassen ·
  1. Hi folks,
    If I use my canon 100mm w/ a 1.4 TC and a canon 500D close up lens, will it be able to focus automatically or will I need to focus manually?
    Daniel
  2. I've used this combination quite a lot with the 7D, 40D and 50D and had no real issues with autofocus other than it is a little slower than the 100 macro with no teleconverter.
    Edit: I'm using the older non-IS version of the Canon 100 macro.
    Edited by Gudge
  3. Daniel,
    I think from what i have read it depends on which 100mm lens u have. The older version with no IS works fine, if a little slower with a TC, but the IS version doesnt seem to work with AF with a TC.
    Im sure others with this setup can clarify, but thats what i understand from here
    Olly
  4. i find the autofocus to be quite slow with teleconverter - if you're patient it will get there. with center point focus on stationary subjects it's still probably better than trying to manual focus. a focus light is probably a good idea. it's going to behave the on land as UW
