Nikon 17-55mm f/2.8 DX and a Sea&Sea housing
Started by pdemaagt ·
  1. I would appreciate some advice on using the nikon 17-55 with a Sea&Sea housing (MDX-D300). Sea&Sea themselves haven't included it in their system charts as an option (which is a bit of a surprise to me).
    Can somebody tell which port (and extension rings) they are using?
    Any help is welcome.
    Regards,
    Peter
  2. I'd recommend stacking an extension ring 40 & an sx extension ring in most domes, and a +2 diopter.
  3. thanks! So you do recommend using a diopter as well?
    Would it make a difference using the large fisheye domeport or the smaller one?
  4. I've only shot it in the 200mm Zen dome, and that was with a +2 diopter. We've had customers use it in the Optical Dome Port w/ +2, but I haven't seen the results.
  5. Just as a reference point, I use the 17-55 with my Nexus FP170 port, which is about 6.75" dia. +3 or +4 diopter depending on subjects I'm looking for. +4 seems to produce a slight sharper image in the corners, but lens will not focus at infinity at the 55mm end - good otherwise. With a +3 it will focus throughout the entire zoom range.
  6. Thanks Ryan and Jim for the inputs!
