Aquatica Still Busy - Port Adaptors (S&S/Subal) and Tripods
Started by TheRealDrew ·
  • 12Posts
  • 12Replies
  1. Aquatica has announced two more products, port adaptors and a tripod. From the official press releases
    AQUATICA INTRODUCES TWO NEW PORT ADAPTERS
    Part of new line of products aimed at recreational and professional underwater photographers
    MONTREAL, CANADA – March 25, 2010 – AQUATICA is happy to announce the addition of two new ports adapters, in what will be an extensive line of accessories to help future user to migrate to the Aquatica system.
    The first is to accommodate the Subal older generation ports (type 3), it is made of anodized aluminum and fits inside the Aquatica bayonet, and therefore it does not add any extension and all lenses normally associated with their ports can be used starting from the Nikon 10.5mm and on.
    The second will accept Sea & Sea NX generation ports, it is also made of anodized aluminum and due to size restriction it does add a small amount of extension, this was calculated to accommodate the popular Tokina 10-17mm without restriction.
    Available spring 2010
    MSRP: 79.00 USD
    AQUATICA INTRODUCES ITS REDESIGNED TLC TRIPOD
    Part of new line of products aimed at underwater photographers and videographers
    MONTREAL, CANADA: AQUATICA announces the introduction of its totally redesigned TLC underwater tripod.
    The inclusion of HD quality video features in the current crop of DSLR as well as the recent advent of HD compact camcorder has increased the acquisition of HD video to unprecedented new levels.
    A tripod has always been a useful yet optional tool in low light / long exposure situations using a still camera. In the case of close up video work using a HDSLR or a dedicated video camera, a tripod now becomes a must have tool allowing for rock steady shots
    This new tripod version includes a pan and tilt head with large easy to grasp knobs and an extended handle for smooth operation when tracking a moving subject.
    Made from specially coated hard anodized aluminum, this tripod will withstand the harshest of environments. It’s simple and robust design guarantees that moving parts won’t seize from the accumulation of sand or grit. The only maintenance required is a good rinse in fresh water.
    The Aquatica TLC Tripod is supplied with three 11” TLC double ball arm sections for support. These can be easily removed and replaced with shorter length arms for a lower point of view. TLC arms come in a variety of lengths and configurations giving videographers endless configuration options.
    A single knob adjustment of this cleverly designed tripod allows it to lie flush at ground level for those hard to get ultra macro sequences. With this intuitive design you can work in a fast, discrete and spontaneous manner to achieve those award winning sequences.
    Here is what renowned Videographer and book author Annie Crawley has to say about the original TLC tripod:
    "I am so happy you have decided to bring this back. I have used the TLC tripod since my very first underwater video system and it is by far my favorite on the market. Mounting it on or off any housing is a breeze! I have used mine for the past seven years! Thank you so much!"
    You can see Annie’s work on her website www.DiveIntoYourImagination.com
    These are some of the features included in the Technical Lighting Control Tripod:
    ß Pan and Tilt head with extended handle
    ß Flexible positioning for fast and easy installation.
    ß Designed to accommodate standard 1” ball arm segments as legs.
    ß Hard coated anodizing process protects components from corrosion.
    ß Simple low maintenance design eliminates lock-ups and freezes due to grime.
    ß Standard 1/4” -20 threaded mounts on most housing tripod socket.
  2. Now you tell me! It would have made my recent housing decision much tougher. Is there a picture of the tripod? I want one and haven't even seen it yet.
  3. Here is the tripod. I assume that it can be used on any housing with a tripod mount?
  4. Here is the tripod. I assume that it can be used on any housing with a tripod mount?
    This with a arca style quick release system would be sweet.
  5. Now you tell me! It would have made my recent housing decision much tougher. Is there a picture of the tripod? I want one and haven't even seen it yet.
    Sorry man, only found out from today's announceement.
    Edited by TheRealDrew
  6. Here is the tripod. I assume that it can be used on any housing with a tripod mount?
    Yes Alex you are right, anything with a tripod hole will fit,
    Sorry Steve, but hey, the tripod should fit your future housing :o
  7. Sweet; both the tripod and the Subal adaptor.
  8. Yes Alex you are right, anything with a tripod hole will fit,
    Are there any plans of doing an Ikelite port adaptor (that is Ikelite ports to Aquatica housings)?
    Regards Bent C
  9. Are there any plans of doing an Ikelite port adaptor (that is Ikelite ports to Aquatica housings)?
    Regards Bent C
    I was just about to ask the same question.
    It would make my future housing choice for the D800 a bit easier.
  10. This with a arca style quick release system would be sweet.
    Absolutely! What I want is a clamp system with a quick release plate on the housing. I suppose you could always just screw a clamp onto the top of the tripod, but that adds even more vertical offset.
    I look forward to seeing the tripod on person later on today (at BTS).
  11. We are looking at a Quick release along the venerable Arca Swiss design already, just was not ready for the show :o
    And the Aquatica to Ikelite adapter is in the plan as well, we are just not there yet... stay tuned
