Ultra Violet Test Shot
Started by Ed_Dman ·
  • 10Posts
  • 10Replies
  1. Here's an UW test shot using Ultra Violet Light.
    1st attempt & result... ^^
    All constructive comment & criticism are welcome. :o
    Ed.
  2. Very cool.
    How did you do it? With a UV lamp or with filters on your strobe and lens.
    Many years ago, I made my own up from a booklet of filter samples. Here is one of the shots:
    The commercial filters from NightSea are probably the best way to go - but I couldn't afford them - and actually found it was very simple to make my own (although I suspect with inferior performance). Always promised I'd do more of this, but haven't got round to dedicating night dives to it!
  3. Thanks Alex... ^_^
    I actually DIY an UV torch for this shot. I didn't use any filters since they are quite expensive & just like you, I couldn't afford them as well... ;)
    I didn't get to test it much, as I had to conduct courses on this trip. I would like to test it more and especially on more colorful marine lives. I like your shot and u should do more, since u might have some interesting ideas that I can use too... :o
    Ed.
  4. Many years ago, I made my own up from a booklet of filter samples. Here is one of the shots:
    Nice shot Alex, did you use a barrier filter?
  5. Here's another test shot with slightly different setting... :o
    Ed.
  6. Here's one, using the filter (UV filter from a shop, but do not know what kind)... :o
    Ed.
  7. aha! you finally tried it. not so bad mister. can't believe you did more night dives though with that group of drinkers you had in the FB photos :o
  8. aha! you finally tried it. not so bad mister. can't believe you did more night dives though with that group of drinkers you had in the FB photos ;)
    Night dive?? What's that??? Sounds familiar.... :o
  9. aha! you finally tried it. not so bad mister. can't believe you did more night dives though with that group of drinkers you had in the FB photos ^_^
    Thanks Mr.Mike... Yup, finally tried but would like to do more testing... :)
    Well... The night dives actually saved me from getting drunk too early... U've seen what they can do in Lembeh before... :o
    Alvin - It is when u go diving at night... ;)
    Ed.
    Edited by Ed_Dman
  10. Just curious... what settings do you have to use to get clean shots with that little light?
